Most common cause of an F7 code on these models is a bad inverter or magnetron. Generally it is best to replace both the magnetron and the 1100 watt inverter board at the same time, since a bad magnetron is usually what burns out the inverter board. If you need further help, I’m available over the phone at https://www.6ya.com/expert/jeffrey_634abadf963e31e5
There will be a technical sheet hidden behind the controller assembly or elsewhere.There is a YouTube video here which shows you how to remove the controller assembly in about 5 minutes.You can also find it online here.It may be a bad door switch, controller problem, inverter problem, or defective high voltage part.You can find
helpful exploded view diagrams and order parts by entering your full
model number from the tag on the oven here.
We're happy
to help you with free advice and we'd appreciate your thoughtful rating
of our answer.
Get the door safety interlock switches tested for continuity and alignment, by a qualified service engineer.
If a door switch is not switchimg. there will be no power to the magnetron and no heating.
Replace the door switches: If cleaning the door sensors doesn't work, it's possible that one or more of the door switches are faulty and need to be replaced. You can follow this video tutorial to replace the door switches yourself3.
If none of these steps work, it's best to contact a professional or the manufacturer's service center for further assistance.
I hope this helps!
The fuse for the Whirlpool microwave model WMH31017HZ07 is located inside the microwave oven. You will need to remove the outer cover of the microwave to access the fuse. Here are the steps to follow:
Unplug the microwave from the power source.
Remove the screws on the top of the microwave that hold the top grill in place. Remove the grill.
Locate the screws that hold the control panel in place. Remove the screws and carefully pull the control panel forward.
Locate the fuse holder on the right side of the control panel. Remove the fuse holder by pulling it out.
Check the fuse to see if it is blown. If it is, replace it with a new fuse of the same type and rating.
Reinstall the fuse holder, control panel, and top grill.
Plug the microwave back in and test to see if the light is working.
If the light still does not turn on after replacing the fuse, there may be another issue with the microwave and it may require further troubleshooting or repair.
It sounds like you are experiencing an issue with your Whirlpool AKP 745 NB oven. The fact that the oven is only blinking with an "auto" text suggests that there may be an issue with the electronic control panel.
A possible solution is to reset the oven by unplugging it from the power source for a few minutes, then plugging it back in. This can help to clear any temporary issues with the electronic control panel.
If the problem persists, you may want to check the user manual for any specific troubleshooting steps or contact the manufacturer for assistance.
Another possible solution to try is to reset the oven by pressing a certain combination of buttons on the control panel, as the manual suggests. If the problem still exists, it is advisable to contact the manufacturer or a professional technician for repair.
It's important to note that, electronic control issues can be caused by various problems, so it is best to refer to the user manual or contact the manufacturer for more specific troubleshooting steps and to get a more detailed diagnosis of the problem.
A bad fuse is one of the most common problems on microwaves, including Whirlpool ovens. Most modern microwaves use the same style of fuse which you can find at most appliance and electronics stores. The difficulty of replacing the fuse in a Whirlpool microwave can vary depending on whether you are working on a countertop microwave or a built-in. Knowing where to start can make the process much easier for either style of microwave.
Countertop Microwaves
Step 1
Unplug the microwave and let it sit for a few minutes before beginning repairs. Bring it to a clear area with enough room to work. Leave enough room to have access to it on all sides.
Step 2
Remove the Phillips screws from the outer shell of the microwave. The screws are located along the lower sides and around the edges of the back. Put the screws into a bucket or bowl to keep them together. Pull the shell away from the microwave, and set it to the side.
Step 3
Look for the fuse inside the exposed controls of the microwave. The fuse is located in a small receptacle with two wires running to it. Use a flat screwdriver to pry up from the bottom of the fuse. The fuse will pop out. Replace the fuse with a new one.
Built-in Microwaves
Step 1
Unplug the microwave, and let it sit for a few minutes before beginning repairs.
Step 2
Open the microwave door, and look for two Phillips screws along the left side of the control panel. Remove these screws. Lift up on the control panel, and tilt it outward. The control panel will rest on its hinges.
Step 3
Find the fuse receptacle within the control area. Is is usually located to the left or center of the cavity. You will see two wires that go to either end of a small, plastic receptacle. Use a flat screwdriver to pry up on the bottom of the fuse. The fuse will pop out. Replace the fuse with a new one.
DO NOT USE LED BULB
<https://producthelp.whirlpool.com/Cooking/Microwaves/Microwave_Product_Information/Replacing_the_Cooktop_Light_on_an_Over_the_Range_Microwave>
