20 Most Recent
Twinhead DURABOOK N15RB Notebook Questions & Answers
Replace laptop fan Durabook
are wanting help as to how to do it, can it be done, or can someone do it for you? clarify question please
11/3/2017 11:21:31 AM •
Twinhead...
Answered
on Nov 03, 2017
Twinhead durabook n15r notebook
I would not put the money into a new motherboard, it would be expensive and in my view better to replace with new laptop especially when you consider the 1 year warranty that is provided ready to go.
3/22/2012 6:16:14 PM •
Twinhead...
Answered
on Mar 22, 2012
When i type the letters
Sounds like the keyboard is in NUM LOCK mode
They keys map like this:
7 8 9 = 7 8 9
u i o = 4 5 6
j k l = 1 2 3
0 . = m .
Look for the NUM LOCK key on your keyboard.
Typically, you press the FN key (lower left corner) and the NUM LOCK key (typically towards the upper right) together to put the keyboard back into regular mode.
4/21/2011 6:19:45 AM •
Twinhead...
Answered
on Apr 21, 2011
During work my laptop gets jam, until i dont take
Your laptop may be getting too hot, or it is not able to cope with the applications that are being run on it. It may need to be upgraded, you might want to concider performing a fresh install of your operating system Windows XP/Windows 7, remember to backup your information. Get your laptop serviced, the technician will remove the dust from the inside of your laptop, this will allow greater air flow through your laptop thus reducing the tempreatures giving you a laptop that will perform at it's optium level.
damnor01
12/10/2010 4:35:37 PM •
Twinhead...
Answered
on Dec 10, 2010
Sometimes the screen goes blank.
There is a ribbon inside ontop of your screen that may have come loose, the only solution is to have someone qualified to fix that...but, if you think that you can do it yourself, you can try that. the screen opens by removing the 5 screws in front of the screen.
Does your screen improve when you move your screen or shake it a little?
4/16/2009 4:04:18 AM •
Twinhead...
Answered
on Apr 16, 2009
Change cmos battery laptop
Tricky for the novice. You have to remove all screws underneath, prise apart case without breaking the loocking plastic clips and then hunt for the battery which may just slide out or be screwed down. It may have helped us if you said what the laptop was
11/3/2017 11:29:44 AM •
Twinhead...
Answered
on Nov 03, 2017
I have a durabook R14K, i need access to bios,
Usually you can acces BIOS by pressing
"DEL" Key duing system startup.
But it also depend on the BIOS manufacturer and version on how to access BIOS
I'm giving you all the key which normally used to access BIOS.
1.DEL
2.ESC
3.F1
4.F2
5.F10
6.F11
7.F12
8.ESC+DEL
try them ,it will surely let you access BIOS.
1/2/2010 12:23:14 PM •
Twinhead...
Answered
on Jan 02, 2010
Cannot install window vista
It is because there is problem with error in harddisk.
For that delete all partition and then create again partition if there is not need to take backup of data.
Try this 4 to 5 times then it works.
Then you can install vista easily.
Also boot computer with vista disk and then enter in recovery console mode then type in prompt "chkdsk /r"
then press "y"
then it fix error on harddiks .
Then check.
Let me know if you need more assistance.
Thanks.
10/16/2009 11:16:56 AM •
Twinhead...
Answered
on Oct 16, 2009
Durabook s13y
Did you try to download all of the updates that are available? You might need to go to the company web site and see if there is a BIOS Flash for your notebook. Vista has a lot of problems that Microsoft can't even explain.
6/19/2008 6:37:10 AM •
Twinhead...
Answered
on Jun 19, 2008
