20 Most Recent Delta Model 300: Classic Single Handle Kitchen Faucet - Chrome Questions & Answers
I replaced the kitchen sink and hooked everything
Check to see that the cutoff valves under the sink are fully open. Also be sure that any shipping plugs or caps in the lines were removed prior to installation.
4/15/2010 2:06:58 AM • Delta Model 300:... • Answered on Apr 15, 2010
Trying to take faucet apart to replace seals
May i get the make and model # of the faucet to help you.
3/31/2010 12:30:27 AM • Delta Model 300:... • Answered on Mar 31, 2010
I replaced the washers and springs to stop drips wtr won't go off
take the handle back off and see if you can turn it off. if you can the you have put one of the 2 in wrong. try reinstalling
8/22/2009 8:06:54 PM • Delta Model 300:... • Answered on Aug 22, 2009
Guess what? The unit in question is a Delta
Instead of the headache, why don't you just replace the difuser? These are relatively inexpensive at home depot and are a simple thread in.
6/5/2009 7:20:05 PM • Delta Model 300:... • Answered on Jun 05, 2009
I have everything unscwered and the only thing
if yu know the size of the nut, go to any of the auto supply store and get a 90 degree box or open end.
most likely is either 1/2 or 7/8"
4/8/2009 7:46:37 PM • Delta Model 300:... • Answered on Apr 08, 2009
When turned on to hard the water sprays out the back of the facet
turn of both water supply under the sink.
there is a small red/blue plastic cap at about 45 degree to the underside of the handle. you need a allen key screw driver to lossen it, then pull up the handle. unscrew the lock cap on top of the facet body. left out the cartirdge and make sure there are two "O" ring at the butom of the cartridge is out of the focet body. install in reverse.
1/9/2009 10:13:46 PM • Delta Model 300:... • Answered on Jan 09, 2009
No water comes through after
these facets are shipped with plastic plugs in them to keep stuff from getting inside them during shipping. Did you remove the plastic plugs where the supply lines hook up?
1/4/2009 1:02:32 AM • Delta Model 300:... • Answered on Jan 04, 2009
2answers
Slow cold water flow in faucet.
Modern faucets are made to be 'Eco', so less water flow and lower water consumption. If the water flow is a lot more on the hot side, there there is a fault with the cold. There aren't many reasons. Stuck shut of valve. Disconnect the braided line and open the valve into a bucket. Or the ceramic cartridge in the faucet is not correctly lined up. Or remove the strainer on the head, they can block with debris. ..
3/17/2024 4:46:22 AM • Delta Plumbing • Answered on Mar 17, 2024
I have a delta touch faucet and the blue led light stopped working. The red is still lighting and the touch feature is working properly. How can I fix the blue led light?
  • Solid Blue - Normal operation, "Touch" mode is activated.
  • Flashing Blue - Normal operation, the hands-free mode is activated.
  • Solid Red - Warning mode - Replace batteries as soon as possible. While the water is running Solid Red LED is illuminated. When the water is off, the Red LED flashes once every 5 seconds. The faucet operates normally, solenoid valve is open.
  • Rapid Flash Red - Alert Mode - Battery Failure Imminent. The Red LED flashes once a second. The first time the faucet is used, the Red LED will turn ON, the solenoid valve will be opened and remain open. The manual valve must be used until the batteries are replaced.
  • Solid Red - Lockdown Mode - Replace Batteries. Extremely Low Batteries - The RED LED is ON, and water will not flow. The solenoid valve is closed and faucet will not operate until batteries are replaced.
  • Long Flash Red (2 seconds on / 2 seconds off) - Board error, replace electronics kit, RP53230 See manual bypass of electronics section of Installation instructions.
2/22/2024 12:39:37 AM • Delta Plumbing • Answered on Feb 22, 2024
Delta Charmaine faucet (19962TZ) set screw button
Try using a suction cup to pull the button out. Place the suction cup over the button and pull it outwards. The suction cup should create enough force to pull the button out. If the suction cup doesn't work, try using a strong magnet to pull the button out. Place the magnet over the button and pull it outwards. The magnet should create enough force to pull the button out. If the above methods don't work, try using a flathead screwdriver to pry the button out. Place the screwdriver under the button and gently pry it outwards. Be careful not to damage the button or the faucet. If this does not work, try customer support for Delta.
1/21/2024 11:21:01 PM • Delta Plumbing • Answered on Jan 21, 2024
How to either break or cut off a Delta single hand tap. I've tried everything to remove it?
Taps lock up and rust. Although the outside is nice and shiny chrome, the inside is brass and they use steel screws that rust in place. Turn off the water, replace the whole thing. Take the parts back where you got them and buy the new one. When you get the new one, remove screws and removeable parts and grease them up with Vaseline.
2/12/2023 7:16:08 PM • Delta Plumbing • Answered on Feb 12, 2023
Brand new Delta faucet and battery case will not stay closed. Only one week old!
Question moved from Cars and Trucks to Delta Plumbing. If it is brand new, you need to contact Delta under warranty rather than Fixya. https://www.google.com/search?q=Delta+faucet+and+battery+case+will+not+stay+closed ..
10/30/2022 3:18:58 PM • Delta Plumbing • Answered on Oct 30, 2022
My delta touch faucet only has small stream what do I do
no info generic answer poor water pressure---valve /water line clogging / failing
4/14/2022 12:55:02 PM • Delta Plumbing • Answered on Apr 14, 2022
Delta cartridge for double-handled faucet will not seat properly.
There a little plastic tab on the cartridge that will line up with a notch in the valve body?...allowing it to go all the way in
3/6/2022 4:06:29 PM • Delta Plumbing • Answered on Mar 06, 2022
Faucet doesn't leak exactly, but...
The classic signs that it needs a new ceramic cartridge and o-rings.
1/5/2022 12:16:17 AM • Delta Plumbing • Answered on Jan 05, 2022
What is replacement number for washers for delta 418sswf
Contact delta they will have that information
9/21/2021 8:45:57 PM • Delta Plumbing • Answered on Sep 21, 2021
2answers
Delta Faucet RP13740 Bidet-Vacuum Breaker leaks from the top.
For me, the issue was the washer that's exposed on the underside of the circular brass piece that's exposed when you unscrew the top (I wasn't able to find any documentation that explains what anything is called). My washer looked fine, but I removed it, added some silicone o-ring lube i had and re-assembled. Stopped leaking.
9/3/2021 1:59:59 AM • Delta Plumbing • Answered on Sep 03, 2021
What degrades in Delta faucet cartridge #RP50587,to warrant 'new' purchase
Water condition, could be a variety of things with water.
7/13/2021 6:25:52 PM • Delta Plumbing • Answered on Jul 13, 2021
Have a 2011 delta purchased kitchen faucet, 2 handle, no handle set screws, how to remove handle
They should simply twist off (unscrew)from the base. Assuming thus is a two handle faucet the "body" right below the handle will simply unscrew reveling the cartridge underneath. Hope this helps!
2/10/2021 2:51:20 AM • Delta Plumbing • Answered on Feb 10, 2021
Delta Model 300: Classic Single Handle Kitchen Faucet - Chrome Logo
10 questions posted
Top Delta Plumbing Experts
john h
vince
Paul Carew
Are you a Delta Plumbing Expert? Answer questions, earn points and help others
View Most Popular
Delta Plumbing
  • Delta Plumbing
Most Popular Question
no water comes after
  • Plumbing
