20 Most Recent
Inverter 220 Volt Tig Arc Welder Questions & Answers
Weld smart inverter arc welder model GR 200 red light ?
For initial info you may try DO & check the ff:
- Check and make sure that the unit was not overheating somewhere,..
- DO unplugging the unit for an hour.
- DO certain adjustment on the cntrol on the unit.
Let me know.
For further assistance kindly update me.
I have Model TR250H Hobart
there should be a switch to go from panel or remote control. and 2 kiinds of foot control 1 just on or off 2 on off with the amps control
Placed a dryer plug on
I don't know about your welder but generally I would not run on less then 40 amp and most all dryer outlets are 30 amps. Also does your welder cord have a secondary ground. Thank you.
EO1 is flashing on the display
Hi:
E 01 means problem with overcurrent or undercurrent, just turn it off and on again and problem should go away. If problem persist contact you welder salesman.
Have a great day.
I cannot get a good edge when cutting its very
ensure you have a good ground connection.
try setting your machine to a lower setting for sheet metal.
approx. 25 amps, and about 2 to 2.5 bar
finally movement is everything, smooth and steady.
settings vary from machine to machine, good luck
I HAVE A NEW TONSENSE SUPER 200 PLASMA
Make sure that area around the tip is clean, and that electrode is ok. Better replacing the electrode. Ensure that there is enough air pressure.
If cutter is arcing, and there is air, then air solenoid is good. If electrode is good, and there is air pressure is fine, then replace the tip. Worn tip is common cause for this problem.
See diagram below on how to find a worn tip:
