20 Most Recent
Bausch and Lomb Bausch & Lomb Hunting Elite 4200 Riflescopes Matte Finish With Sunshade Pow Questions & Answers
Dirt inside my scope how to clean
If you mean dirt on the inside of the lenses like mould growing cheaper to buy a new scope or if flaking internals get a quote for repair
I have a Bausch & Lomb Trophy Riflescope
most things can be fixed again however at what cost???
the scope should be striped down and cleaned new "O" rings fitted to keep out the damp and then re-gased,,,,pricy job?
you could undo the small screw on the scope body and try warming the scope up to force out the damp air inside it then get some "NITROGEN gas" not co2! and blow that into the screw hole to push out any damp air left in it out and to re-gas the scope,,,,it may work it may not,,,,the nitrogen gas can be found at a camera shop check on the gas first but i think its called "dust away or dust off!" for blowing out camera bodys
dont start a gale inside your scope just jentely blow in the gas
Need manual for this scope
Bushnell owns bausch&lomb now they call it bushnell 4200elite scope I would call them for any info you need.
Bosch & Lob elite ed foggy
Bushnell own bausch&lomb scopes and I have had good luck with there customer service. I would call them first .Just make sure you send a detailed letter with scope.Good luck
Bausch & Lomb Balvar 6x24 Rifle target scope
Bushnell owns baush&lomb scope I have called them to repair my elite series bausch&lomb and I have been very happy with there customer service.They might be able to help with your problem to.
FOGGY SCOPE 4200 ELITE BAUSCH AND LOMB
the seals have leaked and some water has found its way into the scope,, it needs to be striped down and new seals fitted all the glass cleand and a regas,,, not cheep
I just bought a rifle with one on it. exactly how
the adjustment on the front eye PC is your zoom.
for your wind edge you have a series of numbers.
some scopes differ some read 5,10,15,etc
some read 1,2,3,4 etc, the # are estimated wind speed,left or right.if the wind isn't blowing set it on 0.
for your elevation you will have a series of #'s
50,75,100,etc.this is your yard edge sight it in at 75 yrd's and if what your shooting at is 100 yards just turn the knob to the correct setting.good luck
RIFLE SCOPE STUCK ON 8x POWER
If the scope's minimum power isn't 8x then it's broken. Call the customer service rep of the company and see how you can return it. Depending on the warranty they may fix it or replace it. I'm not familiar with Balfor as I don't shoot BB guns. You can move the ring around a bit, see if something loosens up, but don't force it.
