20 Most Recent
Pentax Optio E60 Digital Camera Questions & Answers
I accidentally reset my camera
First things first: DO NOT take any more pictures with the memory card that you want to recover pictures from in case you may quite possibly ruin your chances of photo recovery.
Then try this
digital photo recovery software (also recover videos and music) to get them recovered. It should recover your files without problem.
How to Do? Just install the program on your computer, then connect your camera memory card and start to scan.
Remember - Do NOT try & write anything back to your memory card untill you can retrieve your pictures safely!
Pentax Optio E60 won't turn on
Messed with mine for a while and discovered the following:
I mashed the entire directional pad (ok and arrows) with my big fat thumb and hit power at the same time. This apparently reset something inside the camera and it's now functional again.
My camera screen has a CARD LOCKED
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
By prssing the on button
Try the procedures in
this tip. If those don't do it then it'll probably be less expensive to get a new camera, especially give the age of this one.
I lost the CD-ROM disk,
You don't need any software to use your camera.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as
Picasa.
I bought the product without software, can i
You don't need any software.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or, despite what I said first, you can use any photo cataloging program such as
Picasa.
