20 Most Recent
Sony Cyber-shot DSC-W110 Digital Camera Questions & Answers
E:61:00 on display window
Hi there:E 61 00 Difficult to adjust focus Inspect the lens block focus reset sensor E 61 10 Zoom operations fault Inspect the lens block zoom reset sensor E 62 00 Steadyshot function does not work well. Inspect pitch angular velocity sensor E 62 01 Steadyshot function does not work well. Inspect yaw angular velocity sensorThe simple solution to fix that error message was to the let the lens fully extend and give the lens a good whack. Possibly this error message for this means, that the auto focus motor was past the maximum set point.This may sound crazy and this has not happened since I did this but here is what I did to get rid of that error message. I have not had that problem since but here was my steps:• Turn the camera off• Hold the camera face down over a hard surface (Like you are going to take of your desk) with only about half an inch above the surface.OR reference the video files below for an alternate method.• Turn the camera on• Let the lens extend into the hard surface, don't let it extend all the way. Mine retracted slightly and then tried to extend again (let it extend the second time).• Lift the camera away from the hard surface and notice that the error message is gone.• Take pictures of your favorite things.Here is the first alternate method (AVI format)Here is the second alternate method (AVI format)Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.Thank you for using FixYa, have a nice day.
Hi, my camera seems to
i also thought that this happened to me but actully i accidently deleted my photoes myself.can you tell me a way to recycle it back?
Change language problem for Sony Cyber s
Press the HOME button. Use cursor-left/right to select the toolbox icon. Use cursor-up/down to select the "A" icon and then press the button in the middle of the cursor pad. Select the desired language and press the button in the middle of the cursor pad.
I cant see the photos in my memory card when it is plug in the pc
Can you see other files?If you can't see any other files then the memory card could be corrupt.Can you see the memory card in the 'Computer Directory'If not then the card could be corrupt or your computer may not have the correct drivers installed, try doing an internet search for the model of your card and add drivers at the end. Also, try plugging it into a different computerCan you see other types of photos?Perhaps the photos are in the wrong format. If the photos are from a camera you should be able to change the settings to shoot in a different format.
