20 Most Recent
Sony Cyber-shot DSC-S650 Digital Camera Questions & Answers
I own a sony cybershot S650, After recording a
It seems to me that if you can hear audio on TV, that means the microphone is functioning correctly. As to hearing audio from the camera I am not sure whether you can do that. Does the camera have an ear-plug to connect an external headset?
Hope it helps.
Where do I find the volume to hear the recording
Check your menus.
Look for sound on, sound off or some such option.
Most digital cameras have an internal option in the menus to turn off the sound.
Also there should be options to make various parts of the camera sounds to be louder or softer. these are usually for start, shutter button, and others.
Hope it works.
Sony dsc s650 no disc
DSC-S650 is plug and play digital camera, connect it in USB port of computer, Windows will detect it and install required drivers automatically, you will see Device Ready to use message then go to my computer and click on Mass Storage icon click it to copy pictures.
When I take a picture the screen shows the picture
I have the same issue with my DSC s650 , I showed it to a Sony Service center they said its a CCD issue might need to replace that. The cost for replacement in India (Pune) was 2250.So I thought of buying a new one at say 4K INR
My sony cyber-shot dsc-s650 wont
charge your camera battery. if you have reserve batteries available try to use it. if problem persist contatc manufactureror retailer if you still have warranty.
I want to upload pictures from this camera to my
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Hello I need the software
You don't really need any software. Just get a card reader and download to a folder you create on the desktop.
I don't know if its the camera or the USB cable,
Consider NOT connecting your camera to your computer.
I can not transfer my digital pictures because my
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
I couldnt able to transfer
I have a DSC-S650 sony
An easy way to find out is to try another cable. Better yet, consider NOT using the USB connection at all.
My mom gave me her sony cybershot dsc-s650 and
I turn on the camera, "Cybershot" is shown, then a
Your camera almost certainly has a lens error, this
is such a common fault that I hope you don't mind me pasting my stock
generic answer below. No point in reinventing the wheel!
Stuck lenses are probably the most common
reason that compact digital cameras get thrown away, but there's a fair
chance of recovering use of your camera again
The fault is
commonly caused by dirt or grit blocking the mechanism, or due to it
having suffered a recent fall. Another common cause is that the camera
was in a pocket or bag and the power button accidentally activated and
tried to open the lens against resistance. The mechanism may have simply
become
dislodged or there may be parts which have broken.
If your camera
is still under warranty and has definitely not been subject to misuse such as being dropped
then contact the Sony service department in your country to find out about a free repair. If
the warranty has expired though a professional repair will far exceed
the
cost of replacing your camera. You will therefore have nothing to lose
by
trying to fix this yourself.
Please click here
and you will be taken to an excellent article provided by the Camera
Repair website. For the most part, you'll be guided on how to physically
manipulate your camera to try and clear the fault. Although the article
mentions Canon a few times, the advice applies equally to all cameras
with lens errors and is not model-specific.
If the link doesn't work then cut and paste the following address into your browser:-
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Good
luck, I hope you manage to use this information to fix your camera, or
at least are able to use the information to help decide whether to buy
another camera. If you do
decide that you have to throw your camera away then don't forget to
remove the memory card as it can be used in other devices.
Please take a moment to rate the speedy and free answer I have provided
for you and
any testimonial which you might wish to add is always welcome.
