20 Most Recent
LG KM380 Music Phone (Black) Questions & Answers
How do i assign individual ringtones to my lg km380 cellphone
Follow the path:
(1) Menu_Contacts search for the contact you want to assign a ringtone. Select "Options", you will get a Menu containing option "Edit". Select it and you can add or edit a ringtone to the specific contact.
(2)You probably wont get option to assign ringtones, if the contact is saved to your sim. So first u got to transfer the contact to you phone memory. This is how.
Just go to Menu_Contact and search for the contact and press edit, you will get a option "Copy to phone". Select it and copy it to the phone memory. Once copied you can edit the ringtones by following the steps as in (1)
My LG KM380 , when
Sorry you cant retrieve the contacts because you the solution is that you have to get the phone flashed...
Restart problem in lg km380
i dont get it ....what will i do my lg km380 restart automatically and repeatedly.....can you give me another solution..
Whether themes will support to my phone?. can i
Hello :
At the links below you will be able to find millions of themes and download them free of charge. just look for your device in the pages and you will find what you are looking for .
http://www.mobile88.com or www.zedge.net
If this solution is helpful please click a thumbs-up rating below.
Have a great day,
Lg fb163-how to add bluetoth function
To add Bluetooth functionality to your LG FB163, you can use a Bluetooth adapter that is compatible with the device. Ensure that the adapter you choose is compatible with the FB163 model. Once you have the adapter, follow the instructions provided with it to connect it to your FB163 system.
To connect your Android phone to the FB163, you'll need a compatible cable. Typically, you would use an auxiliary (AUX) cable with a 3.5mm jack on both ends. Plug one end into the headphone jack of your Android phone and the other end into the AUX input port on the FB163 system. Then, select the AUX input mode on the FB163 to hear the audio from your phone through system.
