20 Most Recent LG Rumor LX260 Cellular Phone Questions & Answers
it can be unlocked by calling your carrier and they will give you the infomation unlock code as long as the account is current and not delienquent if canceled it will cause some of the features not to work on the device
LG Rumor LX260... | Answered on Jan 03, 2018
LG Rumor LX260 is a CDMA phone and therefore does not use a SIM.
080325180105AAEg3Y2">Sim cards VS CDMA Yahoo Answers
Download manual
LG Rumor LX260... | Answered on Jan 03, 2015
put your phone in a bag of rice for a couple of days and maybe it will draw the water out.
LG Rumor LX260... | Answered on Mar 06, 2014
Operator specific service
LG Rumor LX260... | Answered on Jan 09, 2014
Go to nokia center. I broke my USB port too. I told the staff at nokia care and they agreed to fix it since my phone is still in warranty. I told them i accidentaly broki it and they said they will log it as factory defect. Nice :) I got it back now and they cahnged the entire board.
LG Rumor LX260... | Answered on Jun 26, 2013
Plug charger in over night, try and power on.
If it still doesn't the phone is probably broken and you may need to purchase a new one.
LG Rumor LX260... | Answered on Oct 07, 2012
Press ##3282# and scroll down to advanced, then scroll to password and select view.
LG Rumor LX260... | Answered on Aug 31, 2011
1. Touch > Main Menu > (slide the screen up) >
Settings > Display > Backlight.
2. Select Backlight Dim or Backlight Off.
3. Touch a time setting.
LG Rumor LX260... | Answered on Mar 20, 2011
hi, it is very possible to unlock it permanently or increase the time..all you need to do is to go to setting on your phone...check your phone setting, then try to locate your automatic key guard....you could increase the time or you select off..
LG Rumor LX260... | Answered on Feb 21, 2011
DEAR FRIEND,YOU WILL HAVE TO RELOAD YOUR PHONE WITH A FLASH FILE.
LG Rumor LX260... | Answered on Feb 11, 2011
There are two things that can cause this and you will likely not be able to cure this. The LCD display is scanned by integrated circuits and if the scanning hangs, the circuit fails or a delicate contact strip isn't in the right place on the LCD assembly, you can end up seeing a scan that isn't happening. You can try pressing gently randomly around the surface of the LCD. If you see a flicker of characters or images, then the contact strip is at fault. These are the possibilities but I'm afraid it takes very good manual dexterity and some special tools to correct this at a minimum and if circuit failure is at fault, a new board is needed.
LG Rumor LX260... | Answered on Jan 28, 2011
Well with a new contract with a carrier...no other way.
LG Rumor LX260... | Answered on Jan 04, 2011
I have a LG GU290f mobile phone but my display screen is white and I can't see anything but the phone vibrates and rings when I get my messages and calls I can speak and hear the call properly only my display is white.
LG Rumor LX260... | Answered on Jan 01, 2011
There can be many ways to Unlock your phone. As far as i know unlocking by codes is the simple and safe way. I will suggest the website Unlock-Zone.com which is doing good service and they were recommended highly in the cell phone forums.
I used them to unlock my cell phone. contacted them and within 30 mins i had my unlock code and my phone was unlocked.
Hope this helps.
LG Rumor LX260... | Answered on Dec 21, 2010
most cases having to do with the keyboard, screen, volume buttons or other parts of the phone is mostly related to the flex cable. the flex cable is a thin bunch of tiny wires that are joined together and form a flat extended cable. it is most likely that your phone is suffering from a problem of either a weak or faulty flex cable which needs to be changed.
my advice is that you send it to a repairer because it is a very delicate process which requires some level of expertise. depending on the type of phone and how common it is, the flex shouln't be too expensive for a phone like yours.
hope this was helpful?
please rate
LG Rumor LX260... | Answered on Dec 07, 2010
tbuttercup73HI 0000 is a universal one. Unlest you set a different one. IN arare instance it could be 1234. THose are the most commom ones
I’m happy to help further over the phone at https://www.6ya.com/expert/ronald_e152e07e272e4f27
LG Rumor LX260... | Answered on Dec 03, 2010
LG Rumor LX260 Cellular Phone Logo
93 questions posted
Top LG Cell Phones Experts
William Norris
William Norris
Rusum Gupta
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
View Most Popular
RUMOR LG
  • RUMOR LG
Most Popular Question
phone activation american roaming
  • Cell Phones
