20 Most Recent
LG AX490 Cellular Phone Questions & Answers
Where is the sim card
ok so how do you activate an ax490 alltel phone. mine is bran new never used it well maybe fr a month but i loved it i want ot activate it
6/29/2014 10:33:42 AM •
LG AX490...
Answered
on Jun 29, 2014
I cannot find the sim
Thanks for visiting FixYa!
The LG AX490a was sold by Alltel. Alltel is a CDMA service provider. CDMA service provider's phones do not use a SIM card.
9/10/2011 4:16:26 AM •
LG AX490...
Answered
on Sep 10, 2011
Can someone tell me how
Go to the Menu of your phone and press the 'Multi-media." You can also find it on your screen. Press on it and there you will find the settings that would turn the sounds off
9/8/2011 11:27:31 AM •
LG AX490...
Answered
on Sep 08, 2011
Forgot seurity code for my lg ax490 cell phone.
Hello
OK, if you are talking about the phone security code which
was usually asked when the phone has been restarted, here is how we fix
this.
You will need to enter in the wrong code until you are
prompted to enter the PUK code. Click HERE to read how retrieve the PUK code.
Let
me know if i understood the question.
Kind regards
Andrea
9/19/2010 12:47:46 AM •
LG AX490...
Answered
on Sep 19, 2010
Lg fb163-how to add bluetoth function
To add Bluetooth functionality to your LG FB163, you can use a Bluetooth adapter that is compatible with the device. Ensure that the adapter you choose is compatible with the FB163 model. Once you have the adapter, follow the instructions provided with it to connect it to your FB163 system.
To connect your Android phone to the FB163, you'll need a compatible cable. Typically, you would use an auxiliary (AUX) cable with a 3.5mm jack on both ends. Plug one end into the headphone jack of your Android phone and the other end into the AUX input port on the FB163 system. Then, select the AUX input mode on the FB163 to hear the audio from your phone through system.
How can I hatd factory hard reset my LG 265 if I don't have my pin # nomore or forgot it .
- Turn the phone off.
- Press and hold the Power/Lock key (on the right side of the phone) and the Down Volume key (on the left side of the phone) at the same time.
- When the Factory data reset screen appears, release both of the keys.
- Use the Volume keys to highlight Factory data reset, then press the Power/Lock key to confirm.
- Use the Volume keys to highlight Yes, then press the Power/Lock key to confirm one more time.
- Your phone will perform a factory reset.
Im locked out of my
WARNING : Performing a hard reset will remove ALL data including the Google account, system data, application data, application settings, and downloaded applications.
- With the phone off, press and hold the Home key, Volume Down key and Power button. When the LG logo appears, release only the Power button.
- Release the Home key and Volume Down key when the Android icon appears.
- Follow the on-screen instructions.
Can an LG Stylo 4 with a cracked screen , showing only a black screen be repaired so i may extract data from it ?
It is possible to repair an LG Stylo 4 with a cracked screen that shows only a black screen to extract data from it. However, the success of the repair will depend on the extent of the damage to the screen and other internal components.
You can take your device to a professional phone repair shop and ask them to repair the screen. Once the screen is repaired, you should be able to access your data on the device. If the screen repair is not possible or too expensive, you may be able to extract data from the device by connecting it to a computer with a USB cable and using a data recovery software.
Note that data recovery software may not be able to recover all the data from the device, especially if the device has suffered significant damage. It's always a good idea to regularly back up your data to avoid losing important files in case of accidents or device failure.
