20 Most Recent
RIM BlackBerry Bold Smartphone Questions & Answers
I can't turn my blackberry on.
The battery has been drained too much. You'll need to get a new battery or the battery needs to be externally charged to at least 50% externally
I bought my son a
When you send over bluetooth on a blackberry and the handset pairs you need to select the file type you are send and be in the folder to received. Once in that folder you need to click the blackberry key and select received via bluetooth.
SIM not provisioned: 2
This happens when the phone and the sim is unable to communicate...this may either be due to the problem with sim like it is yet to be activated or not properly inserted etc.Try to reinsert properly using the manual or call the customer care incase of activation problem.There is also a chance that the phone may be network locked with a particular carrier and you are trying to use it with other networks.In that case get the respective unlock code fom the network provider or legit third party unlocks like
UnBBlock.com and remove the network lock from the phone.This will solve the problem.
Call barring
go to settings and click call settings and you will see it and will be able to change that to were you get call barring
My blackberry bold screen is very dark and I can't
try to go into settings, there should be a setting somewhere in there saying power saver or something, turn that off if its not already. otherwise, there must be something wrong with the screen lighting , like its blown or something.
