20 Most Recent
Sony VAIO PCG-V505CP Notebook Questions & Answers
Hey my laptop, on start
The error indicates that the Hard Drive in the computer has crashed and will require a replacement.
I made a quick search and found the part # of the HDD that was shipped with your model. It is
A1065524A. I would suggest that you replace the HDD with one with the same specification that was came with the computer.
You may either purchase it from Sony parts center or third party vendors.
Thanks!
12/13/2010 6:28:47 PM •
Sony VAIO...
Answered
on Dec 13, 2010
Need sound drivers for laptop
Have you tried the Sony web site and download the driver you required. Recommended for the correct driver for your machine.
7/25/2010 11:12:51 AM •
Sony VAIO...
Answered
on Jul 25, 2010
Sound card for sony
I'm assuming you mean drivers...
the wireless driver is here:
http://www.sony-asia.com/support/download/product/pcg-v505cp/modelfirst
I can't find the sound driver, but you should be able to either 'update' the driver from the device manager, or download all sound drivers from the following link, burn to CD, and let the computer update from that automatically... http://driverpacks.net/driverpacks
7/25/2010 10:44:11 AM •
Sony VAIO...
Answered
on Jul 25, 2010
In battery is dead
Mostly this problem comes up if you dont shutdown your computer properly as in by offing it by holding the power button and stuff like that. What you can try doing is when you on the computer it should let you choose if you want to go to the BIOS menu or System Recovery and you go to System Recovery and if you would like reboot the whole computer or just choose to repair the windows and it will reinstall the windows files only which should take care of the problem.
1/2/2009 6:14:42 PM •
Sony VAIO...
Answered
on Jan 02, 2009
Dead Sony Laptop
If power supply is supplying correct voltage, then you do not need power supply PCB.
Try starting the laptop with AC adapter and no battery, if battery is shorting out you may get same problem.
Test the soldering joint on the AC socket and laptop motherboard, if there is a bad soldering on laprop ac adapter socket, you get same symptoms.
If it is none of the above, and the adapter is fine, then it is usually a faulty motherboard.
11/16/2008 2:16:15 PM •
Sony VAIO...
Answered
on Nov 16, 2008
Code error 0xc0000185
Do you the Windows user suffer Error Code 0xc0000185 on your PC or laptop.
Well, this is a blue screen of a ***** error note telling me that your boot configuration info is missing (Error Code 0xc0000185)
This BSOD error code issues with a note - The Boot Configuration Data for your PC is missing some required information.
Causes of Error Code 0xc0000185:-
1. Suffer a cable attachment joining to your system and the hard drive.
2. Defective or missing boot files.
3. The disk drive gets damaged.
4. Wrong disk drive.
Solutions of Error Code 0xc0000185:-
1: Do sure that Wire is Correctly Connected [Only for PC]
2: Automated Repair
3: Check Hard Disk for Errors
4: Repair your System to Fix Error 0xc0000185
Full Solution -
9/14/2022 11:53:07 AM •
Sony VAIO...
Answered
on Sep 14, 2022
