20 Most Recent
Sony Vaio FZ31M Notebook Questions & Answers
I can't start up windows
When you first power on, is the text visible? Hit the F2 or F3 key to get into bios to see if the text is readable. If so, then you possibly have corrupted video drivers. If it's nothing is visible, check your video cables and video card. If you are able, try a different video card. If everything is visible, then boot into low res safe mode and reinstall your video drivers.
Wi fi is appearing to other devices
I have a finlux 42" 3d tv. My pc is connected but it only shows the background picture and not the icons or start bar? how do i fix this please? thank you.
Set Up PC to TV
What type of video card does your pc have??? if it is an nvidia card, you have to go to the control panel and set up for dual monitor..when you connect your laptop to an external monitor, you have to press control and f8 keys for couple of times ...that adjust the color to 256. Are you doing that?
Let me know
Recovery f10
You should check on eBay.If your main recovery partition been removed hope you need new OS installation that's all i have found on my search.If you got product key still on your laptop you can buy with out product key window vista or window 7 from eBay which will cost very low price and boot it.
My sonny vaio's display has garbage on it (it's
i think i have the same problem with my Toshiba Satellite p100 i am having a heap of pixels with the wrong color on my screen and the thing is that the number of pixels position and color depends on the image on the screen any help
I HAVE A VERY BIG PROBLEM WITH MY NOTEBOOK
Hi. Thanks for your question.
There's few things you can do to reverse this. First i would try is to restore system to previous date. To do this follow these steps.
1. Restart machine and while starting up back again press F8 key.
2. Once screen with question what you would like to do choose "safe mode" and press enter.
3. When in safe mode go to Start--->All Programs--->Accessories--->System Tools---> System Restore
4. Choose the date when computer was working well and press Restore.
In few minutes it should be working back again. Please don't hesitate to ask more if further assistance is needed. Good Luck
Code error 0xc0000185
Do you the Windows user suffer Error Code 0xc0000185 on your PC or laptop.
Well, this is a blue screen of a ***** error note telling me that your boot configuration info is missing (Error Code 0xc0000185)
This BSOD error code issues with a note - The Boot Configuration Data for your PC is missing some required information.
Causes of Error Code 0xc0000185:-
1. Suffer a cable attachment joining to your system and the hard drive.
2. Defective or missing boot files.
3. The disk drive gets damaged.
4. Wrong disk drive.
Solutions of Error Code 0xc0000185:-
1: Do sure that Wire is Correctly Connected [Only for PC]
2: Automated Repair
3: Check Hard Disk for Errors
4: Repair your System to Fix Error 0xc0000185
Full Solution -
9/14/2022 11:53:07 AM •
Sony VAIO...
Answered
on Sep 14, 2022
Lost video on svt131a11l
Try to:Open Computer by clicking the Start button and then clicking Computer.Navigate to the folder or drive that used to contain the video file, right click it and then click Restore previous versions. https://8ballpool.onl/ https://googlehangouts.ooo/ https://omegle.onl/
9/30/2018 12:52:58 AM •
Sony VAIO...
Answered
on Sep 30, 2018
