20 Most Recent
Sony VAIO VGN-CR220E/W Notebook Questions & Answers
How to solve the problem
You need to bring it in to a repair shop as soon as possible. If it is leaking liquid, that liquid is toxic and shouldn't be left where kids or animals can accidentally get into it. It shouldn't cost too much to have the screen replaced at a local repair shop.
9/5/2012 7:16:28 AM •
Sony VAIO...
Answered
on Sep 05, 2012
I have got Sony Vaio. When I installed Intel
Please download and Run the BIOS update utility for resolve this issue. You can download it from the link below.
Download
If the problem still persist, reboot the Computer and keep tapping the F2 key when VAIO logo appears on the screen to enter BIOS mode. You can manually disable the function System and BIOS Shadowing. This will resolve the issue.
Good luck..:)
9/20/2010 12:05:47 PM •
Sony VAIO...
Answered
on Sep 20, 2010
I can't to open my adobe acrobat 8.0 profesional
If you want to open a pdf files then you can you Adobe reader or Foxit reader which are both freeware.
Adobe acrobat 8.0 is not a freeware and you need to buy the license key in order to installed the software and activate it.Do consider buying if you want to use adobe acrobat.
or else you used "Free PDF Editor"
Here is the downalod link
http://www.freepdfeditor.net/FreePDFEditor.exe
Happy New year...
12/31/2009 11:58:32 AM •
Sony VAIO...
Answered
on Dec 31, 2009
White horizontal lines appear in the screen
you may just need to reseat the cables. basically all you have to do is take the keyboard bezel off of the laptop and disconnect and reconnect the cables on the lcd. you usually do not need to unscrew anything but a pick would help. Just simply pry it off using a pick or small flathead
12/10/2009 5:05:51 AM •
Sony VAIO...
Answered
on Dec 10, 2009
Dvd-rw drive driver and device
First thing I would try is go into Device Manager and uninstall this device, then in Device manager choose action>scan for new hardware.
If that doesn't do it go to manufacturer web site and look for the latest driver and in stall it.
If you need help with any of this post a comment and I will give you more details.
Andy
11/9/2009 10:09:55 PM •
Sony VAIO...
Answered
on Nov 09, 2009
Why can't I watch tv on my vgncr22oe? does my
You will need a tv tuner dongle that plugs into the usb port. These are available from all good PC stores. They do these for all formats of TV so you would be able get one that decodes cable and you would have the added benefit of being able to use your laptop as a PVR so you can record your favourite programs straight to your laptop.
9/30/2009 1:05:51 PM •
Sony VAIO...
Answered
on Sep 30, 2009
Code error 0xc0000185
Do you the Windows user suffer Error Code 0xc0000185 on your PC or laptop.
Well, this is a blue screen of a ***** error note telling me that your boot configuration info is missing (Error Code 0xc0000185)
This BSOD error code issues with a note - The Boot Configuration Data for your PC is missing some required information.
Causes of Error Code 0xc0000185:-
1. Suffer a cable attachment joining to your system and the hard drive.
2. Defective or missing boot files.
3. The disk drive gets damaged.
4. Wrong disk drive.
Solutions of Error Code 0xc0000185:-
1: Do sure that Wire is Correctly Connected [Only for PC]
2: Automated Repair
3: Check Hard Disk for Errors
4: Repair your System to Fix Error 0xc0000185
Full Solution -
9/14/2022 11:53:07 AM •
Sony VAIO...
Answered
on Sep 14, 2022
