20 Most Recent
Lenovo IdeaPad Y530 Notebook Questions & Answers
Change a wallpaper on my lenovo G570
It depends what opperating system you have - for example - if you have windows 7 home edition - you cant change it (: if you have the pro edition you can :)
Whenever I turn on my lenovo ideapad y530, it
Goto BIOS ( Press F12 or F2 button repeatedly when the computer restarts)Goto Boot device configuration and select your hard disk as the 1st boot devicePress f10 to save your settings and exit or press esc and select save and then exitCheck if your are able to see the screenElse Try going to safe mode with networking ( You can goto safe mode with networking by - restart your computer and start pressing the F8 button repeatedly till you get the new boot options menu)Select safe mode with networking and login and if your are able to , then try restoring the computer to an earlier date to which it was working fine.If all these steps failed, then it might be the start up files corrupted issue and you need to repair your installation of windows with the windows CD you haveI have had the similar kind of issue and was not aware what to do. While searching the web, I got the info about TheBestPcDoctor and I contacted their support. My issue is fixed and the computer is running fine now. If you need you may also contact them @www.thebestpcdoctor.com or via 877-407-9229
My labtop cable is broke
There are a couple of options for replacement. You can contact IBM/Lenovo and get a new factory replacement. The other option is to look on a site like eBay and try to find an aftermarket one. You can search on the model of laptop and you should find a few options. Make sure to look for one from a seller that has a great rating to ensure the best results.
Lenovo Ideapad- screen has begun
The screen control board coudl be goign bad. The heatsheild in the screen could be the cause. The cable that sends the signals to the screen could be bad. The graphic chip could be overheating or could be starting to detatch from the motherboard.This is not something you should look at yourself. It is best to be taken to a technician.
How to set wallpapers on lenovo notebook?
Welcome to Fixya
Open one of you pictures that you wish to put as desktop wallpaper. Right clikc on it then select set as desktop background. You can also right click anywhere on your desktop and click properties. Click the desktop tab then click browse button, search the picture you want to put as wallpaper then click open. Click apply to set the picture as wallpaper.
Thank you for usign Fixya! If you need further help, reach me via phone at
https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
How to change my wallpaper
Windows 7 --> At dekstop front page, Right click >Personalize > Click Dekstop Background > Choose pivture > Save
Windows XP --> At dekstop front page, Right click > Properties > Dekstop Wallpaper > Browse your picture file > OK
or just open Windows Explorer > Open Folder where you save the picture file > Click file > Right Click > Set as Dekstop background > DONE
Hope this help and if this helpful RATE please.
Lenovo idea pad Y530 model name 4051 web camera is
hi,
try o press and hold Fn Esc,that will allow you to enablrd/disabled the camera capability,if nothing happens,try to download the driver from this website,consumersupport.lenovo.com, type the serial no and look for the camera drier and the designated Operating System and for the bit as well,if its a 32bit or 64bit... for the keyboard,try to do a system restore from the time that the keyboard is properly working,if nothing happens,obviously,its a hardware problem and you need to contact lenovo for keybaord replacement
thanks
How do I install a 2 gig upgrade chip in a y530
Hi. Actually you can just remove the RAMS or memory that you need to replace with that 2GB of memory. If you're looking for a step by step how to over the internet I think could not find it even if you google it. Im a Lenovo Tech Support technician thats why I know this information, If you want a step by step guide on this issue you can Lenovo Hotline at
US/Canada: Available 24/7 1-877-4LENOVO (1-877-453-6686)
Australia: Available 24/7 1300-557-073
New Zealand: 9am-9pm Mon-Fri 0800-446-833
Hope this helps
My lenovo y530 pretty much just died.
unplug power supply remove battery and let set for a bit.replace battery and try to turn it on..you probally have corrupt the hard drive..if all indicator lites are flashing then its working and maybe the screen has been corrupt or broke.if you have a desk top monitor around you can hook it up to your laptop and see if you can see anything on that,and if so you can go in and check all the drivers are working properly especially the monitor and graphics..yes a desk top screen will hook rite up to a laptop.
