20 Most Recent West Bend 55108 Espresso/coffee Maker Questions & Answers
2answers
I want to know the closest location to get a
www.bizrate.com/coffee.../coffee-maker-replacement-parts
or
www.nelsonappliance.com/Coffee+Maker+Parts.html
or
www.marbeck.com/coffee_carafe.html
or
www.all-about-coffee-makers.com/coffee-maker-parts.html
12/21/2022 6:42:16 AM • West Bend 55108... • Answered on Dec 21, 2022
2answers
Failed coffee maker
the "sensor" (little white hard material disc) works in conjuction with the heating element Ok thats a no brainer, however usually it is the heating element failure (lloks like a big U thing on bottom of hot plate) that kills the sensor. Both have to be replaced, however, are they easy to find and worth the cost of parts and time to repair?? Or just buy another one. The life expectancy is aproxiamate 500 or less pots...
6/28/2014 8:54:11 AM • West Bend 55108... • Answered on Jun 28, 2014
Every time I meke coffee my machine have swill sound and don't make full amount of coffee
Many times when a coffee machine is not working properly, it needs to be cleaned. Pour 1/2 & 1/2 White vinegar and water into machine as if you making the coffee, and turn machine on. It make two treatments t clean out the machine. You can then use some baking soda in water to neutrlize the vinigar.
5/7/2014 3:56:56 PM • West Bend 55108... • Answered on May 07, 2014
0answers
0answers
The espresso maker doesn't work
All coffee makers have a 'thermal fuse' inside to prevent a melt-down of the heating element in case the controller fails.These fuses are made (probably exclusively) in China and are the most common failure in these machines.Unfortunately, they are welded onto one end of the heating element meaning that to get your machine working again, the heating element (including the fuse) will have to be replaced.Since this is such a common ill, West Bend may have a recall on them (many other manufacturers do) or offer a reduced price repair.
11/29/2011 3:40:57 PM • West Bend 55108... • Answered on Nov 29, 2011
How to make expresso on
I purchased a 55120 coffee and espresso combo machine and it did not have the manual with it.
Could you please tell me how or where to go to download one.
[email protected]
7/14/2011 8:07:29 PM • West Bend 55108... • Answered on Jul 14, 2011
Need a carafe for west
Repacement parts are available online here:
http://www.westbend.com/catalog.cfm?dest=itempg&itemid=2706&secid=87&linkon=subcategory&linkid=115
Sorry someone has not responded sooner.
5/17/2011 2:45:24 AM • West Bend 55108... • Answered on May 17, 2011
I need a replacement coffee carafe for the West
You may order a replacement carafe online from the following site:
5/17/2011 2:32:57 AM • West Bend 55108... • Answered on May 17, 2011
Our Thrift Store received a West Bend "3 in One"
The Instruction Manual for the West Bend 55108 3 in 1 Coffee Center can be found here:
http://www.westbend.com/supportdata/L5563G_55108-3in1_All.pdf
Available replacement parts may be ordered online from these sites:
http://www.westbend.com/catalog.cfm?dest=itempg&itemid=4400&secid=87&linkon=subcategory&linkid=115
or
http://www.abtecparts.com/Westbend_coffee_makers.htm
5/17/2011 2:28:43 AM • West Bend 55108... • Answered on May 17, 2011
I am trying to find
Replacement parts for your West Bend 55108 can be ordered from either of the two sites below:
or
3/24/2011 8:11:13 AM • West Bend 55108... • Answered on Mar 24, 2011
Need a carafe replacement model
If you need to find parts for your West Bend slow cooker, West Bend coffee maker, West Bend Blender, West Bend popcorn maker, West Bend breadmakers, West Bend rice cooker/steamer, West Bend griddles/skillets/grills, and West Bend toasters/ovens the best place to go is www.westbend.com.
Also checkout this tip as it will help you to find what you are looking for on the website.
West Bend Kitchen Appliances Parts and Manuals
heatman101
2/8/2011 3:37:07 AM • West Bend 55108... • Answered on Feb 08, 2011
0answers
Made a pot of coffee
Remove the on/off switch and check with an Ohm Meter for continuity. If one is not available run a jumper wire from each wire to the switch. It may work then. If so the switch is bad. If not the resistor inside the circuitry is most likely the problem
12/26/2010 2:43:08 PM • West Bend 55108... • Answered on Dec 26, 2010
West Bend 55108 Espresso/coffee Maker Logo
Popular Tags
64 questions posted
Top West Bend Coffee Makers & Espresso Machines Experts
Mike Cairns
Mike Cairns
Sulejman Sulejmani
Sulejman Sulejmani
Kolbrun...
Are you a West Bend Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
View Most Popular
West Bend Coffee Makers & Espresso...
  • West Bend Coffee Makers & Espresso...
Most Popular Question
espresso maker doesnt work
  • Coffee Makers & Espresso Machines
