20 Most Recent
Acer Aspire 9410 Notebook Questions & Answers
Acer computer screen went white and black
If the mouse is newly installed may be theres a problem in the port drive of your acer computer or one of its components been corrupted. So as your monitor doesn't work since display components and its, drive have been missing. YOu have an acer CD, try to repair or perhaps it needs to reformat your Acer computer.
My laptop screen went out
Did you hit the keys that makes you toggle to an external display. Sometimes you just can't connect an external monitor, you have to hit keys that toggle between display on laptop only, display on both laptop and external or display on external only.
Bios password reset
Try removing the main battery and unplug the power, then hold the power on button down for 30 seconds, if this does not work, remove the cmos battery for 30 seconds to reset the bios
Upon turning my laptop(acer aspire 9410) on I get
Sounds like your windows explorer isnt starting
Please press control + alt + delete, on the task manager click start new task..
Then type in explorer.exe
that should bring up your windows desktop for you.
My acer 9410z won't recognize my sd card-how do I
First install your usb driver and then try it. otherwise i think it can be operating system problem. the better for you of Windows XP or Vista.
Finally, everything is okay then the problem is in your sd card slot. please consult with a professional technician near about you. thanks.
We sent before email to
For the BIOS setup try pressing the F2 button on and off as the power comes on - this should bring up the blue Bios screen - but if the screen isn't working you won't see it.
You could try moving the screen up and down to see if the screen come back.
It can be the lighting behind the screen that's broken - not a DIY repair
My acer aspire9410 disply is
-changeing bios-first restart computer then press[ f2] then get on key board use arrow key on key board go down you will see your boot log is on f2,change that on a f12, now push f10 to exsept settings now when asked restart computer then f12 then run windows under D:drive.
How do I disable shadowing
You can type "services" in your windows search box and click on the services with the gadget to get to your service manager. Then go down to "volume shadow copy" and disableor stop and then change startup type to manual to keep it from restarting.
Miissing operationg sistem
As what you stated, you don't have an operating system so you need to install one for your laptop to work.
Hope it helps.
Thanks.
I can't access my web
Try installing the latest WEBcam driver.
Download the drivers from the Acer WEB site. Make sure youselect the model of your laptop and the XP or Vista version of the drivers youthat require and it matches the Windows version that is installed on yourlaptop. Use this link to get to the Acer support: -
http://www.acersupport.com/drivers_download.aspx
