20 Most Recent
Tissot T33.1.588.71 Wrist Watch Questions & Answers
Centre Sensor no longer functioning
You are need to send it into tissot for a service. You cannot fix this problem on your own. There is a two year warranty for tissot. Hopefully you will be eligible.
4/9/2017 12:56:02 AM •
Tissot...
Answered
on Apr 09, 2017
TIME IS NOT THE SAME AS THE DIGITAL TIME
- Push the middle (T) button.
- Touch the screen in the center selecting the units mode (24 C m).
- Push the middle (T) button again for 5
seconds.
- "SYNCHro" will appear on the display.
- Use (+) button for min arm and (-) for hour arm.
- Bring the two hands pre-cisely to 12 o'clock.
- Press the middle (T) button to validate the setting.
7/9/2013 10:18:39 AM •
Tissot...
Answered
on Jul 09, 2013
Set time/date How??
Follow this link:
http://www.tissot.ch/index_offer.php?c=eu&l=en
Find and download instructions for your watch. Site is quite complicated, but you will find all the info you need if you've got patience.
Rate me, please.
3/15/2009 12:55:01 AM •
Tissot...
Answered
on Mar 15, 2009
Can't get the watch to synchronize
Your battery maybe down in power ie not much longer before it runs flat this seems to cause the problem you descibe ..otherwise it should set as long as you are following the correct procedure from the manual
1/27/2008 2:55:33 PM •
Tissot...
Answered
on Jan 27, 2008
Wot size battery do I need for a t472 tissot trace
I think that's a SR936Sw or equivalent. That watch has a pop-off back, so its easy enough to access. You'll need a jewelers pincers or something like a sharp pin to extract the battery (Carefully!) as its embedded in the body.
Why Touch does not work after battery replacement?
Was the battery empty in the first place, or was the watch already defect?
Did you put in the correct and a new battery? or perhaps you did put n the old battery?
can you measure the voltage of the batteries, to check?
Just a few questions that came up with me.
How to set moon phase on tissot pr100
for Tissot PR100 Automatic Chronograph with moonphase, minute recorder, hour recorder and seconds subdials, to set the moonphase
there is a sunken button between the chronograph start/stop and the winding crown.
Using a pointed object such as a ballpoint pen, push the sunken pusher gently until the moonphase moves one step, (if you press the pusher completely in, it will also advance the calendar hand, so only press enough to move the moonphase and no more for moonphase adjustment)
