20 Most Recent Bachmann Big Hauler Radio Controlled Train Questions & Answers
Where do D batteries go?
They go into the coal tender. Push and lift on the coal shoot for the boiler in the cab.
10/5/2019 2:45:56 PM • Bachmann Big... • Answered on Oct 05, 2019
Is there a battery on engine car?if so where
batteries are placed in the loco boiler. access through door on boiler backhead in cab.
12/12/2014 10:10:29 PM • Bachmann Big... • Answered on Dec 12, 2014
Is there a battery on the engine? if so where? or in any other train car
open the door on the boiler backhead in the cab, slide batteries into the boiler. r/c unit also takes a battery.
12/12/2014 10:08:19 PM • Bachmann Big... • Answered on Dec 12, 2014
We purchased our son the Bachmann Big Hauler train set (used). All works fine, with the exception of the r/c transmitter. The very tip is broken off and therefore, does not allow the transmitter to w
best option is to look for one on one of the online auction sites. be sure it transmits on the same frequency there should be tags on the locomotive & transmitter identifying the frequency.
10/15/2014 4:17:39 AM • Bachmann Big... • Answered on Oct 15, 2014
How does the 7.2 volt rechargeable battery work in the Big Haulers RC sets?
Open the door on the back of the boiler(inside the cab), the battery pack should slide in, then close & latch the door.
10/10/2014 3:07:19 AM • Bachmann Big... • Answered on Oct 10, 2014
How is Bachmann's Blue Comet's locomotive powered.
The backhead on the boiler inside the cab of the locomotive opens up and you install cell batteries into the boiler to run the locomotive..
10/24/2013 1:33:40 PM • Bachmann Big... • Answered on Oct 24, 2013
Cant find where the batteries go in train
in the cab of the locomotive, you will see the backhead of the boiler. you should be able to open it and slip the batteries into the boiler.
1/29/2013 1:17:02 AM • Bachmann Big... • Answered on Jan 29, 2013
Bachmann big hauler casey jones
Post it for sale on one of the online auction sites.Check eee-bay for completed listings on Bachmann setsto give you an idea of what people are paying for them.Also compare prices of the individual pieces, to seeif it would be more profitable to break up the set.
1/28/2013 9:45:36 PM • Bachmann Big... • Answered on Jan 28, 2013
Want to sell my first generation Big Hauler G scale set. Pristine. In original box. Complete with extra track. How much is it worth?
The Generation 1 Locomotive, is of minimal value.Best bet if you want to sell the set is to part it out and sell the cars separately.Locomotive, & tender w/rc transmitter ~ $15.00 - $25.00Cars ~ $20.00 - $25.00Track ~ $2.00 - $2.50 per section.If sold as a set, probably would be lucky to get ~ $50.00
1/28/2013 1:25:00 AM • Bachmann Big... • Answered on Jan 28, 2013
Where do the batteries go in the 90-0100-27?
The backhead of the boiler in the cab opens and batteries are inserted into the boiler.There also should be an adapter cable to enable your to use an R/Ccar type sub-C rechargeable battery pack. It is only 7.2 v. so it will run a little slower.
1/20/2013 3:10:37 AM • Bachmann Big... • Answered on Jan 20, 2013
MY R/C TRANSMITTER # 90-0100-A27
Hi Jiggs,
Double check the batteries with a tester. I've gotten them drained off the shelf. They do have expiration dates.
Make sure the battery connects and springs are clean and shiny, free of corrosion.
Next, make sure they are put back in the right direction. I know, but it happens. Check anyway.
Make sure both units are powered on.
That's the easy stuff.
Next step requires making sure the leads to the antennas are tight and free of corrosion.
If the set is new, Do not open anything as this will void the warranty. Bring it back for exchange.
Best regards
Mike
11/19/2010 3:47:19 PM • Bachmann Big... • Answered on Nov 19, 2010
2answers
Don't have instruction manual for
hi, im trying to locate the owners manual for you and will post it here as soon as i find one but you need to leave me a response so that i can post another message to you and hopefully the link to the owners manual.
Now as for the battery's the batteries are located in the enginge (locomotive). They take 6 D sized batteries. At the very back there is a panel that you need to slide off to get to the battery compartment. Somtimes it may take a little manipulation to get the panel open. As for directions, Iam in the same boat with that problem. Hope this helps
that should at least give you a good idea of where the battery's go if you have any troubles post me message back then i can assist you further ok
12/23/2009 6:16:15 AM • Bachmann Big... • Answered on Dec 23, 2009
WE have just gotten my
The batteries are located in the enginge (locomotive). They take 6 D sized batteries. At the very back there is a panel that you need to slide off to get to the battery compartment. Somtimes it may take a little manipulation to get the panel open.
9/10/2009 7:55:17 AM • Bachmann Big... • Answered on Sep 10, 2009
It won't run.
Check the battery contacts, they may be corroded. If that does'nt work, if you fell confident enough, open the locomotive and check for loose or dissconnected wiring. Also, make sure your transmitter is the same frequency as the tranE. Hope this helps!
9/10/2009 7:50:46 AM • Bachmann Big... • Answered on Sep 10, 2009
My son has been left
The batteries are located in the enginge (locomotive). They take 6 D sized batteries. At the very back there is a panel that you need to slide off to get to the battery compartment. Somtimes it may take a little manipulation to get the panel open. As for directions, Iam in the same boat with that problem. Hope this helps.
9/10/2009 7:47:01 AM • Bachmann Big... • Answered on Sep 10, 2009
Transmitter power lite is on but no power seen at engine-
There are two switches at the rear of the engine. One turns the sound on and off and the other turns the power to the engine on and off. Make sure you have the power switch turned on. It should default to full forward with the transmitter off.
1/4/2009 12:06:56 AM • Bachmann Big... • Answered on Jan 04, 2009
I bought bachmann spectrum 2-10-2
sounds like it's too lightweight! try running with a big blob of plasticine on top, to see of it runs right. if it then works ok you need to fill the internal spaces with lead (ask your local tyre shop for the weights they take off wheels when changing tyres)
9/21/2017 4:52:01 PM • Bachmann Crafts... • Answered on Sep 21, 2017
866 engine problem
What's the problem?
5/6/2014 5:09:09 PM • Bachmann Crafts... • Answered on May 06, 2014
Broken idler/reduction gear in ho power truck
Hi Jerry- Split gears, unfortunately, often occur with plastic gears especially the older an engine gets it seems. They get brittle and crack. I've provided a link to the Bachmann website-they offer a catalogue of parts and may have the replacement gear you require. You can also call them toll-free (the number is on the site) and provide the nice person with the model of your engine. A little known fact is that Bachmann used to provide a lifetime guarantee on their locomotives. If the part you require is no longer made, they sometimes offer a replacement engine (new) at a substantial discount. You will have to mail in your old one. I used this service one time and received a brand new engine for about 60% off the cost of it new. A good deal! My only other suggestion is to check in your area for local model train shows. You can search for them online. Most of the vendors are hobbyists themselves that sell model trains and supplies to make a few dollars on the weekend. Their trains are usually used but sell for a fraction of the price new. Sometimes you can purchase a beat up engine for its parts for a couple dollars, and sometimes they have parts that have been taken off used engines themselves. Bring your engine along with you and see what you can find. I find bringing an old engine back from the dead always very rewarding! Hope this helps! Happy modeling! Bachmann Trains Online Home
4/1/2014 8:48:27 PM • Bachmann Crafts... • Answered on Apr 01, 2014
2answers
I am thinking of making a scrapbook for my sisters baby shower but I have no idea where to start. Any suggestions?
Scrapbooking is a wonderful way of giving your sister a real personal memory of this special time. Check out this Daily Motion video for an idea to get you started, http://www.dailymotion.com/video/xffl74_how-to-make-a-functional-baby-shower-scrapbook_school
4/24/2024 5:18:30 PM • Crafts & Hobbies • Answered 17 hours ago
Bachmann Big Hauler Radio Controlled Train Logo
Popular Tags
33 questions posted
Top Bachmann Crafts & Hobbies Experts
xxxxxx xxx
ADMIN Andrew
ADMIN Andrew
Carolyn Rogers
Are you a Bachmann Craft and Hobby Expert? Answer questions, earn points and help others
View Most Popular
  • Bachmann Crafts & Hobbies
Most Popular Question
son left
  • Crafts & Hobbies
