SOURCE: Screen color is purple
if you have access to another monitor use if to verify the monitor is the problem and not the video card of the computer.
does the monitor allow you to adjust color and tint(hue) because the tint or hue control changes the overall color from green to purple. or the color control circuit has failed leaving you stuc with a purple screen.
SOURCE: Monitor will not show any indication of power.
4 years is a good life for a monitor, so i agree you can stick to Dell since its already proven itself... :) - As you mentioned, this monitor is not currently being sold from Dell, I would suggest an upgrade to a 19" - http://accessories.us.dell.com/sna/productdetail.aspx?c=us&cs=19&l=en&sku=320-5629 or a 23" one http://accessories.us.dell.com/sna/products/Displays/productdetail.aspx?c=us&l=en&s=dhs&cs=19&sku=320-7339 ... if i were you, i would choose a 23", but for a higher pricing :)
SOURCE: Monitor gone black but shows self test not floating
Sounds as though the control unit has died. There are 3 parts to most monitors. The video processor board, power supply board and the HV/backlight board. You can replace the video processor board.
Make sure you leave the unit unplugged first and set for an hour. Usually no other fix then replace the board.
SOURCE: Can't set to optimal resolution
cheeck the device manager in your laptop right click my com pand go ro properties and then in device manager and there look for display adapter click on the plus sign over thereand there it will give you an otpion and right click there and then uninstall the driver and then restart the comp and then place the driver and utilities cd in the cd drive and then install display adapter and then again restart the comp hope so your issue will be resolved
