Which model of APEX TV do you have?
In general, if the TV has had the source changed, you will need to switch it back from Air (OTA) to CATV (cable). Newer TVs may have the choices of Air and Cable for the TV source.
To change the setting, press Menu (on the TV (if present), on the original remote (in TV mode) or on a substitute remote with the Menu function). Use the up/down arrows to select the TV submenu. Select this menu with the right arrow. Then go down through the submenu to the Source line. (It may read CA-TV/Air on an older TV.) Use the left/right arrows to toggle the setting. Then press Menu to save the setting and return to the previous menu. Then go to the CH Scan option in this menu to rescan the available channels.
Note: I've gone through the directions for an older Apex TV (AVL-2076) with an analog (NTSC) tuner. The directions will probably be similar for other TVs but the menus (and sub-menus) may have different names or be in a different order.
I hope this helps.
