Refrigerators Logo
Posted on Aug 04, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When I turn the ref. on after 3-4 days my evaporator coils covers with ice and my refrigerator is not cold. The freezer freezes though
Anonymous
Level 3:
  • Refrigerators Master 43,501 Answers
  • Posted on Aug 05, 2011
Anonymous
Level 3:
Answers
43501
Questions
0
Helped
10842661
Points
101584
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Whirlpool refrigerator is not getting cold but freezer is freezing. Can someone help, please?
As the freezer is working you can probably discount that the reason is low refrigerant gas. The other reasons would be that the fridge circulation fan has failed.
or
The channel that directs cold air from the freezer is blocked with ice at the rear of the freezer. It happened to my GE and was caused by a failed defrost timer that was icing up the evaporator coils at the back of the freezer.
A service call lasts about an hour including melting the ice with a heat gun..
1helpful
Coils freeze up and fridge runs all the time till I melt coils.
There might be a few causes
Door Seal might be defective causing the door not to shut tightly this causes air from the room to get into the freezer through the opening and as the air comes in contact with the evaporator coils, it freezes. Normally the defrost system removes the ice but if the seal is defective the coils freeze too quickly and the defrost system cant keep up
If the freezer evaporator coils ice over, the defrost thermostat might be defective. Several times a day the defrost heater turns on for a few minutes to melt away any frost that may have accumulated on the freezer evaporator coils. In order for this to work, the defrost thermostat has to sense that the coils are cold enough. If the coils are cold enough the defrost heater will turn on. If the thermostat is defective it may not be able to sense the temperature of the coils and then won't turn on the defrost heater. If the defrost heater doesn't turn on, the evaporator coils ice over and eventually no air will be able to travel through the coils to provide cooling to the freezer. The defrost thermostat can be checked for continuity. It should have continuity when it reaches the low temperature of its operating range.
Condensate drain inside of freezer compartment keeps filling up and freezing and then overflows to bottom of freezer compartment and freezes. Have made sure drain line is clear. Problem occurs about every...
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer or on floor
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
5helpful
Ice keeps building up on the freezer floor in my Kenmore refrigerator freezer. though I have turned the freezer setting down to cold from very cold, this continues to happen
Leo Ponder
imufo2
Ref not cooling
remove the access panel in the freezer section and see if the evaporator coil is iced over,a little frost is o.k.,but when they are covered with ice they can't pass cold air,if this is the case defrost the coil with a handheld hair dryer,then check the defrost heater under the coil for continuity,if its good then suspect a defective defrost control be it timer or adaptive defrost
Freezer section not freezing
If you only had ice buildup in one section of the evaporator you have a weak/inefficient compressor.
You need a new compressor or a new refrigerator.
3helpful
2answers
I have an admiral model HMG 67184 side by side and I can't figure out why my freezer section still works but doesn't get cold enough to make ice cubes and the other side doesn't work at all. I do have...
1. Get the Food out of the Ref and Freezer. Unplug the power cord from the wall.
2. The cooling coil is in the back wall of the freezer side. Working from inside the Freezer.
3. Remove the back plastic cover to expose the cooling coil. It's called the Evaporator coil.
4. Use a hair dryer to melt all ice off the coil.
5. Put it back together. It should work for 3 - 5 days now at least.
6. Put a thermometer in there. After 24 hrs. the freezer should be 0 to 10 degrees F. and the Ref. side 37 to 44 degree F.
7. Check the door gaskets for tight fit, using a dollar bill for a gauge.
Shut the door on the dollar and try to pull it out in several places.
If it ices up again in a week or two, you have a defrost heater problem. There is a electric heat strip around the cooling coil. This heat strip comes on about 10 minutes every 8 or 10 hours. This heater melts the ice off the coil. There is a clock timer device under the ref. that cycles the heat strip. You may have a bad clock, fuse device or burned out defrost heater strip. The cooling coil must be ice free to work properly.
Freezer compartment of refrigerator not freezing
First, I think it’s important to know that the Ref side has no cooling coils, it’s basically a box and the cold air in the freezer is blown over by a fan through a channel into the Ref side. This channel has a door which regulates how much cold air goes through. You probably have two control knobs in the Ref side, one controls the temp with numbers 1-9, 9 being the coldest. This temp control tells the compressor how long to run. The other control is for that little door and it may have letters A-E, E being the coldest. If you set it on E (coldest) then this will close that little door and keep most the cold air in the freezer.
So, how can the Ref side be cold and the freezer side not freezing?
1. Coolant leak. There is enough coolant to keep the Ref side cool but not enough to freeze on the freezer side.
2. Defrost system failure. The coils on the freezer side are clogged with ice and it's just a matter of time when the Ref side won't cool either. The back wall in the freezer will be covered with ice/frost
Freezer gets cold, Refrigerator Hot
Now, why is that cold air not getting over to the Ref side?
1. The little door is not open.
check your control setting. You can't see the door but, you should be able to feel air coming through the channel on the Ref side.
2. The fan in the freezer is not working.
You can hear this fan running when you open the freezer.
3. The coils on the freezer side are clogged with ice which won't let the fan circulate the air over to the Ref side.
This is a failure of the defrost system which consist of the defrost timer, heater, and thermo disc.
Also, If you replaced the evaporator fan then you got a good look at the cooling coils. Look at these coils while it is running. There should be a light coat of frost on all the coils. If this frost line is only 3/4 or 1/2 or any amount less than full coverage of the coils then the system has a coolant leak.
Directly under these coils is the drain pan and drain hole in the middle. This area should be clear of any ice or debris.
4helpful
2answers
Refridgerator not very cold
It could be some many things, to save time let me give you this check list:
Do what you feel qualified to do.
If you found this helpful please Vote. Good Luck!
Top Refrigerators Experts
ZJ Limited
ZJ Limited
john h
