I DROP MY WATCH CODE REF IS 1142 I BROKE THE GLASS WHERE CAN I BUY A REPLACEMENT GLASS FROM
Getting a glass shouldn't be a problem, but as it sounds as though you intend to fix it yourself, then please be aware of the following.
It is essential to get the correct size glass - even 0.5mm difference in the diameter means either it won't fit or it's too small and falls out again. As you say that the glass is broken, I would be surprised if you could remove it and still determine the correct diameter.
You need to think not only about how to remove the broken glass, but also about how you are going to fix the replacement one. Many watches have a very fine plastic ring around the glass that holds it in place and this may have also been damaged.
Also, with many watches it's necessary to remove the back, crown and movement to effectively replace the glass.
If your watch has any sort of water-resistance rating then it would need to be retested afterwards.
Bearing all this in mind, I strongly advise you to take your watch to a reputable watch repairer and let them sort it out.
If the glass is anything other than round, then the cost tends to go up. Get an estimate from them first, and decide if what they will charge you is reasonable - if it isn't then spend the money on a new watch.
Hope this is helpful.
Hi, I have the same watch and have chipped the glass, did you find anywhere to fix yours? I REALLY want to repair it!! Any help would be gratefully received
