Hi E3 is an overload error
and indicates that the washer motor is not running properly. You can take out
some clothes and then restart the cycle by pressing the START/PAUSE button.
After this, if the error appears again then check the motor connections, if
everything appears fine then the motor should be replaced. Hope this
helps...please post back for further assistance. Daniel
SOURCE: Stops working chimes and E3
Hello
In order to try and assist you with this problem I will need specific information about the washers MAKE and MODEL number. Thanks
