SOURCE: Samsung HP-T4264 will not autoprogram, locks up on
Reset to factory specifications by turning tv on, and then using the remote, hit power off, mute key, 1, 8, 2, and power on. Interval between key strokes is less than 3 seconds. When tv comes back on it shows Service Mode Display, key up to reset and press enter. Was able to autoprogram without any problems.
SOURCE: I have a Samsung HP-T4264 plasma tv with a badly
No way, Jose!
Those bastards manufactures are always making sure you won't be able to use parts from one model to the other. Especially-display! LCD panels could be rigged, but no plazma's. Sorry!
Sell it for parts to some repair shop and get yourself LCD or LED panel. Plazma is gone!
SOURCE: my samsung hp-t4264 cuts off after a few minutes
I had the same problem. Fix it using the firmware update from Samsung Website. The customer support people are ****. They said it would caost be 500 to fix it.
SOURCE: Samsung HP-T4264 plays for a
had the same exact problem. The customer service people at samsung were **** and had no clue. After doing some research I narrowed ti down to two potential problems. First one was check for the blown capacitors on the power suplly board. You can find lots of forums on this and is a very well known problem with samsung. Second, which was my fix, is try the firmware update for your TV from the samsung website. The rpoblem was fixed in 30 seconds and no money spent. The clicking and tv on and off problem is gone. Good Luck.
