SOURCE: reset Norstar M7310 System Administration password
This works, i just did it today!!
Press Feature 985
Press the 9 Key
Enter RESETSMPSWD (73738767793) using the dialpad
Press YES
Once you have RESET the password, it reverts to the default.
See Below
If your system uses 2 digit extensions use 120000
If your system uses 3 digit extensions use 1020000
If your system uses 4 digit extensions use 10020000
SOURCE: nORSTAR m7310
To Log Into System Programming:
Press FEATURE * * 2 6 6 3 4 4
Enter Password: 2 6 6 3 4 4 Display will read: " A. Configuration"
Using the navigation keys, as displayed below, follow the next simple steps:
Press: NEXT Display will read: "B. General Admin"
Press: SHOW Display will read: "1. Sys speed dial"
Press: NEXT Display will read: "2. Names"
Press the SHOW Display will read: "Set names"
Press: SHOW Display will read: "Show set:__"
Enter the extension number of which you wish to change the name Display will read: "<##:name>"
Press the CHANGE softkey
Using the dial pad spell out the name Ex: If you need the letter
K press the 5 key twice and then press # to confirm the letter.
Continue until the entire first name is spelled. (note: you are limited
to 7 characters)
Press: NEXT (if you fail to do this step, the name will not be saved!!!)
Press the RLS key
Hope this helps!
SOURCE: Norstar ICS 4.0 password
How to Change a Mailbox Password
1. To access the voice mail system press "Feature".
2. Press "983".
3. When you see "Log:" enter "120000" for 2 digit extension numbers, enter "1020000" for 3 digit extension numbers.
4. Press "OK".
5. Press "MBOX".
6. Press "CHNG".
7. Enter the mailbox number you wish to reset.
8. Press "Reset".
9. Press "Rls" to exit (orange button to the right of the number buttons).
Default password is "0000".
SOURCE: I have mistakenly changed the password to the CCR
to reset the administrator pasword enter feature 985 press 9, at the password prompt enter 73738767793 (resetsmpwsd) and press ok or #,press yes to reset password. password should be defaulted to 0000. then try Feature 983. if your system has 2 digit intercom #s your password is 120000.
Testimonial: "The solution was right on! I was able to reset the password and update the greeting message. Thanks for the help."
