Vacuums Logo
Posted on Aug 04, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The power just cut out on my purple & green dyson
  • Official Brand Answer 2,572 Answers
  • Posted on Aug 05, 2011
AskDyson
Level 0:
Answers
2572
Questions
0
Helped
1769428
Points
6009
Sorry to hear you're having difficulties with your DC04 Absolute. If the cleaner cut out during use, the thermal cutout switch may have shut the cleaner off because it was overheating. It would be a good idea to wash the filter, and to check the airways for blockages. The easiest way to do this is to follow the steps shown in our online support guide:
http://www.dyson.co.uk/support/help.asp?article=51&product=DC04-PL-ABS
By washing the filters and clearing any obstructions, you should resolve your issue. However, if you're still concerned, please get in touch with us directly so one of our experts can run through some troubleshooting checks over the phone with you. You can call us free on 08002980298 - our Helpline is open from 7am until 10pm, 7 days a week.
Kind regards,
Jack
Dyson Customer Service
My dyson DC35 keeps cutting out and also I am not sure if it is charging as the green light doesn't come on which is situated on the plug. I have ha days it about 4yrs.
4 years for a battery powered Dyson is very good. Most only go half that or less. Do some honest research before you replace it. Call your local vac shop for expert advise.
My handheld dyson is not working - initially it was cutting out after only a few mins then seconds now it won't work at all despite showing green light ??
Hi there, it's Jack at Dyson.
I'm sorry to hear your DC31 Animal is only working intermittently. When fully charged, this machine should have a maximum runtime of 10 minutes, or 6 minutes on the maximum power setting.
There are several factors which could cause this, and to determine what's at fault we'd need to take you through some quick diagnostic checks when you have your machine to hand. The machine would also need to be fully charged, so please make sure it's had 3.5 hours to recharge before calling us.
You can reach our freephone customer Helpline on 0800 298 0298 (UK), or 1-866-693-9766 (US). Our experts will be happy to help further.
Best wishes,
Jack
Dyson Online Customer Support
http://www.dyson.com
1helpful
HOW TO REMOVE SOLEPLATE PLEASE TO CLEAN cleaner dyson dc07
On the underside of your Dyson, there are 3 coloured fasteners with slots in the heads which secure the sole plater. Turn each one 90 degrees with a coin or large flat-bladed screwdriver and then lift the edge of the sole plate where the fasteners were located. It can then be removed. If your Dyson is yellow/grey, the fasteners will be yellow. If it is purple/grey, the fasteners will be purple, etc.
Feb 09, 2011 • Vacuums
2helpful
No power to Dyson checked plug & fuse both ok any Ideas
Hi its Darran at Dyson.
If the machine cut out during use this will be the thermal cut out. This is caused by the motor becoming too hot during use, due to a blockage or a dirty filter. full details on how to resolve this can be found on our website at www.dyson.com. Simply click on Support and you will find all the info you need.
If the machine has cut out and wont switch on again after being left for a few hours, it sounds like an engineer will be required to inspect and repair the machine. You can contact our Helpline on 0800 298 0298 (UK) or 1866MYDYSON (US).
Kind regards
Darran
1helpful
What size cable do i need to replace damaged cable
Mains flex, Twin Core, 6 Amp (0.75mm2).
Most electrical shops will sell it by the metre. They'll probably have it with a choice of grey/black/white/orange outer sheath. However, if your original cable was purple, and you really, really want it to remain purple, the only place I know to get this is from Dyson themselves.
Electrically, it doesnt matter what colour the outer sheath is !
How do I open the dirt cannister on a dyson animal (purple) so I can empty the dirt out?
This is fairly easy. Click on the button at the top of the hand above the cannister. It's a purple button and the handle faces the front and says Dyson on it. This separate the cannister from the body.
Next, hold the now full cannister above a trash can and click on the red button which was below the purple button (but hidden when it was attached).
Power Loss - Suction Loss
Hi
Its cutting out because its overheating.
Change the filters and check the base and the hose for blockages
Top Dyson Vacuums Experts
AskDyson
AskDyson
Sean Wright
Sean Wright
xxxxxx xxx
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
