Question about Furuno NavNet vx2 1920C GPS Receiver
Ais and 1920c Furuno chart plotter
I have connected a Furuno fa-100 AIS to a 1920c Furuno Chart Plotter through a 1500 Interface unit according to the instructions that came with the interface unit. The AIS feature soft key remains grey and the symbols do not show up on the chart plotter. The chart plotter has the 320b GPS receiver antenna. It is connected to port 2 on the 1920c. Please help.
  • 4 more comments
  • r5hoops Sep 02, 2008
    I can't see how having the bearings displayed in the magnetic mode instead of true can have anything to do with the fact that the chartplotter doesn't seem to recognize the AIS.
  • r5hoops Sep 20, 2008
    I finally managed to get the chartplotter to show the AIS targets. I had hooked the 1500 Interface to the connection box exactly as the book that came with interface showed. When nothing that I tried worked ( adjusting the settings on the AIS and the chartplotter, checking the connections over and over and asking advice from the ship's Engineer and anybody else that I thought might know a solution) I was ready to admit defeat and call a Technician in to fix it. In desperation I tried hooking it using the schematic that came with the AIS and it worked. I had it hooked that way at the start but decided that because the manual for the Interface spelled out how the connection should be made I should go with it. That was the mistake.
    r5hoops.
  • Anonymous Mar 13, 2014
    When I connect Chart Plotter to 12Vdc it sound beeper and flashing "STARTING UP SYSTEM".What should Ido?
  • Anonymous Mar 14, 2014
    Furuno AIS FA100 Password
  • Anonymous Mar 22, 2014
    turned on my NS25 chart plotter and the only chart that came up was a sample
    President:
  • 1,952 Answers
Utstanding reputation of Furuno's original NavNet network's reliability, performance, and expandability. Like its predecessor, the NavNet VX2 System combines radar, GPS/WAAS chartplotter, fishfinder, and network weather FAX. From a stand-alone, single station, multifunction navigation center to a four-station integrated navigation network, NavNet VX2 lets you build your navigation system specifically to your needs. Utilizing state-of-the-art Ethernet network technology, NavNet VX2 provides seamless data sharing and vast future expandability while remaining completely compatible with the first generation NavNet System. Whether it is the radar and GPS/WAAS antennas that connect directly to the NavNet VX2 displays or the optional network sensors that connect through the Ethernet network, all of the data obtained from each sensor can be shared and controlled by every display on the network. Once you select your display package, plug the network black box sounder into any display or an Ethernet hub and turn the NavNet VX2 display into a high performance dual-frequency fishfinder. The BBWX1 Sirius Satellite Weather Receiver works with the C-Map MAX Displays to show weather maps, satellite images, NAVTEX, and other navigation information. And it doesn't stop there. The Rate Compensated Heading Sensor allows radar images to be overlaid on the chartplotter. The options and configurations are too numerous to list. The reality is Furuno's wide range of options fulfills virtually every need you may have for your navigation system. So dream up your ideal Furuno navigation system, and we'll help you put it together.
The 10.4" NavNet VX2 Display Package comes with one of eight different commercial-grade Furuno radar antennas. The output power of the antennas range from the sleek 2.2 kW radome to a powerful 25 kW open array. The 7" NavNet VX2 is available with your choice of a 2.2 kw or 4 kw radome antenna.
Posted on Sep 02, 2008
    Brigadier General:
  • 3,614 Answers
Copy of your manual, kindly check in here:
MODEL 1824C MARINE RADAR MODEL 1834C MARINE RADAR MODEL 1934C ...
    Genius:
  • 1,142 Answers
N the system setup, under “UNITS” I set BEARING to “MAG” (magnetic). This will cause the unit to display course / bearing information in relation to the Magnetic North and match magnetic compass readings. It is not the same as True North! One has to be careful with this setting. There are a number of areas where the earth's magnetic field is locally disturbed, sometimes very significantly. Your GPS may not account for it. - again, under “UNITS” I set “METRIC”.
SOURCE:
Would like to change the Ship's Name, MMSI and Call Sign, anybody can help on the Furuno Fa 150 AIS???
try going to the ships register and applying for the changes
there will be a marine department that will point you in the right direction
Apr 03, 2017 | Furuno GPS
Password for ais furuno fa 150
I have tochange themmsiofan apparatusfurunoaisFA100, you knowyour password?thanks
Jun 20, 2012 | Furuno Boating
Furuno FA-100 with MaxSea?
set io port speed for ext io 4800 on opencpn works ok
Feb 21, 2012 | GPS
I have a Furuno Radome RSB0094-075 with a Navnet RDP 139 10.4" What I dont have is the antenna cable to connect the two units. What cable should i be ordering for this?? Thanks, Mike
That is a Furuno 1823C Radar -000-138-972 (10 meter Radar cable) $150.00 msrp from Furuno. Give their Camas Office a call or your nearest dealership. The Furuno number in Camas, Wa 888-834-9330
Nov 06, 2010 | Furuno NavNet vx2 1920C GPS Receiver
NMEA Output from Furuno 6" LCD Radar, Model 1623
No it does not output any type of radar video data.
Apr 27, 2010 | Furuno 1623 Radar 16nm Range
Furuno 1850 has water in unit, only noticed
http://www.fixya.com/support/r3771170-phone_water_damage
Nov 06, 2009 | Furuno 1850WF Gps Fish Finder Combo...
My furuno navnet vx2 periodically freezes during operation and must be restarted. Any suggestions?
Reinstall the operating software. The unit should probably go to Furuno.
Try operating it with only a GPS connected (no radar, no network). If this resolves it, it is almost certainly software. It could be low voltage or failing mother board.
Jul 15, 2009 | Furuno NavNet vx2 1920C GPS Receiver
GPS/plotter/sounder will turn on and operate properly. Unit will
Try removing your chart card then powering up your unit. Chances are your chart could be bad and is causing the problem.
Jun 08, 2009 | Furuno GP1850DF GPS Receiver
Adapt 997c si gps to navnet furuno sounder
no can do you must have a Furuno GPS or a GPS with NMEA 0183 output. you could get that from the Hummingbird display but not straight from the antenna
Feb 27, 2009 | Furuno NavNet vx2 1920C GPS Receiver
My ais targets are out of line showing them out of the river
If the AIS targets are out compared with radar target then turn compass to superimpose radar on to AIS.
If the AIS info is out compared with chart then suspect GPS. This could be yours or theirs depending on how many targets are out and whether it consistantly in one direction.
Good luck
Mike
Dec 12, 2008 | Furuno NavNet vx2 1920C GPS Receiver
Furuno NavNet  vx2 1920C GPS Receiver Logo
496 people viewed this question
Top Furuno GPS Experts
Andrew Taylor
Andrew Taylor
Are you a Furuno GPS Expert? Answer questions, earn points and help others
