Jus type 800000 and the safe will open like magic.. Its their default factory reset code.. CHEERSJus type 800000 and the safe will open like magic.. Its their default factory reset code..
CHEERS
Re: I typed the wrong key code while closing the godrej...
To unlock a high security safe without breaking its integrity will be a tough job for you but i guess the following link may provide you with some assistance: http://www.youtube.com/user/harisonkeys?feature=mhee
Low battery voltage will allow display to work but not enough power to operate release circuit which requires more power - try new high energy batteries.
To reset the combination on a Sentry safe, open the door of the safe, delete the existing codes, press the PROG or P key and enter the factory code. Finally, enter a new five-digit number as per individual preference, which is the new user combination.
It is always prudent to reset the combination on a Sentry safe when the door is open because it prevents the user from being locked out. To open the Sentry safe door, type the five-digit factory code given in the owner's manual. This factory code cannot be altered.
To delete the existing codes on newer models of the safe as of 2015, press the P button. Then, type the factory code and follow it up by inputting "00000" into the safe. On older models of the Sentry safe, press the PROG button and type the factory code two times.
After deleting the existing codes, press the PROG or P key and then enter the factory code once again. Within five seconds, type a new five-digit number, which is the new user code. To verify if the user code is working, retype it and then close the door of the safe. The user code is the primary code for opening the safe, and users can reset it as often as they want too
Follow this link: https://www.youtube.com/watch?v=E7nWCVN2aME
In the comments you will find that some time ago default password was 2125. If it won't work then movie will show you other method.
To open a Safe International Digital Electronic Safe
User override key to open safe
Then:
a. Inside the open door you would find hidden a red button press this button, the yellow light will be on, input the user code in 30 seconds try 1,5,9 then press A or B to finish
b. If the yellow light keeps flashing with beeps the code is wrong( revere to user manual)
CHEERS
If it is not opening by this no. Also
I have the same issue. it is keep on saying error. Can anyone help?
