Hi. I have a Whirlpool electric range (model rf363pxpt0) with standalone burners - the burner power indicator light stays lit whether the heat control knob is on or off, there is no heat coming from the burner on or off. I pulled the burner from the receptacle and one of the tabs broke off and stayed in the receptacle. I removed the tab and made sure no pieces remained in the receptacle then bought a replacement burner, no change. I put the replacement burner in the back burner of the same size and had heat within 10 seconds. I changed out the burner with the one that had been in the back of the range, no heat. As long as the breaker to the range is on the power light stays lit but no power to that one burner only.
Whirpool Electric Range Burner Light Stays on but no heat
Hi
I
have a whirpool cooking range------with glass top.Three burner are
working but problem with the big front burner.When i switch on the
control knob the light stays on but the heat is not coming
I need a suggestion if it is a burner broken or control knob problem.Please advise
Hi
I
I was an idiot. I was working on the wrong switch, from left to right on the left side the front burner is on the outside, the back is on the inside. This is reversed on the right side of the stove which I didn't realize. Once I figured this out, I had to get a switch that was rated much higher than the smaller one. The minute I replaced I put in the new switch and turned on the power, it has been working fine. Thanks for trying to help, much appreciated.
Hello givemeanidth.
Welcome to Fixya
You said, have a Whirlpool electric range (model rf363pxpt0) with standalone
or off. You pulled the burner from the receptacle and one of the tabs
broke off and stayed in the receptacle. You removed the tab and made sure
no change. You put the replacement burner in the back burner of the same
size and had heat within 10 seconds. You changed out the burner with the
What is the model number and the age of your range?
Waiting for your reply.
Huuum
triple burner does not cycle stays on super high setting, does not turn down.
