Posted on Aug 16, 2017
I have a 4 yesr old Jamo S 502 DVD surround sound system. The playback freezes intermittently and i took it to Genserve in Swindon for repair. They have advised that the replacement laser is not available. I wrote to Jamo but no luck there. I would like to try and get the unit repaired if possible and it seems crazy that the laser cannot be replaced in a unit relatively new. an you assist?
5 Related Answers
Anonymous
  • Posted on Sep 28, 2006
SOURCE: Error Message H02
I have had this problem on numerous times. Once while in warranty. Discussed with technician and he reported that the gears get dirty and stick and need cleaning. Since last year, I get this message every 3-4 months. I take out all the screws from the bottom, open the cast carefully, and use some canned air, clear all the gears, gently rotate all of them. Put everything back together and should work fine.
Anonymous
  • 108 Answers
  • Posted on Dec 22, 2007
SOURCE: Technics Cd player doesn't read disc. Says no disc.
You cannot replace the new lens your self. coz there are some process to replace a new lens. withour much knowledge of servicing you might damage the new lens too.
try to find some substitute for your technics lens
A
Anonymous
  • Posted on Mar 13, 2008
SOURCE: Sony STR-K660P Intermittent sound problem
xdfcbzdf
Anonymous
  • Posted on Dec 03, 2008
SOURCE: Polaroid FLM 323B - No picture
Problem Solved, I replaced the third capacitor (the same mf and V as the other two) and now it works great. I'd like to say "Thanks" to all of the folks who had a helping hand in this one!
harley07825
  • 23 Answers
  • Posted on Jul 17, 2009
SOURCE: Sony STR-SE501 makes popping sound/cuts off
just repaired my se 501 poor solder conections on blue rleays by speaker jacks,also blown center speaker seems there are 2 in it one blew and so did cpacitor running now just hooked up one in center speaker sonds great also stay at 8 ohms setting
Need manual please for Theater Research TR-502 5.1 Surround Sound
Good day. The best I can do for you is a link where you must request the manual online. Go here http://www.audiocircuit.com/Home-Audio/Theater-Research/TR-502#manuals. Hope this helps!
I have a jamo S DVR 502 surround sound system approx 2 years old. I have looked at the circuit boards and have found several damaged components, which look like overheating problems. The board No is...
Hi again Ray
Not sure what happened... I was about to tell you that some models of gear do not make it down under...
If you wish to pursue the fruitless quest for a board that can be simply repaired.... the Jamo distributor UK contack numbers can be found here.
I would have been able to assist you with repairs to the board, if you had some knowledge of electronics for me to work with. I suggest that you contact them direct and enquire as to the warranty temrs for the gear. You left the call before I was able to
tell you that they have 3 years warranty here in Au...
Good luck.... thanks NOT for your patience.
regards
robotek
Hi, I have a rumbling noise coming from the sub woofer on my surround sound system. Any ideas?
Is it only at high volume or all the time? It could be that your input from your DVD may be bad.
Intermittantly freezes on playback. Toshiba rs-tx20 dvr
shut down tv/dig box/dvd. unplug and then leave a little (cuppa time)
replug .then start up dig box then tv then dvd.sounds like in need of "reboot"
Jamo i330 i-pod dock has one channel out
I WOULD LIKE 2 NO IF I CAN RESET MY PASSWORD 4 KLH SURROUND SOUND SYSTEM. I BOUGHT AT A SALE AND THERES NO WAY I CAN FIND OUT PASSWORD. IT IS A KLH SURROUND SOUND SYSTEM DVZ-2500 MODEL # IS 0044224000657.I WOULD ALSO LIKE 2 NO IF AND WHERE I CAN GET A MANUEL....
1helpful
2answers
Where do i purchase remote control for jamo home surround ?
Hey I have a DVR50 which appears to have given up the ghost. Its probably beyond economical repair but I'm gonna try the service centre later today. If you have any trouble getting a new remote I'll gladly send you mine if I have to scrap the DVR50. I'd rather someone get something out of it. Just pay the postage and thats fine. [email protected]
The display on my Onkyo TX-SR 803 is blank does not light up. Everything is functioning properly. Volume light is lit. Any suggestions.
This is a common fault, I got in touch with Onkyo and they referred me to a company called GenServe based in Swindon.  My receiver was under warranty and I live near Swindon.  The company was very helpful and fixed the problem in a couple of hours!  It's worth calling them on 01793 886333. www.genserve.co.uk
Speakers
Any make should do, just be sure the ohms match or else you run the risk of damaging the speakers if they are under rated, or the reciever if they are overrated. Usually it can range from 4 to 8 ohms, which is represented by a horseshoe shaped symbol.
Movie freezes, skips.
Does sound like the laser. Realitically, not worth repairing. I'd say you'd be worth connecting a cheap DVD player to the system - then the Sony can carry on providing the surround sound audio and the new DVD player can provide the video. Then, if the cheap DVD player is still going, it can move to a bedroom TV if and when you replace the surround system....
Otherwise, I would imaging the speaker set (and even the non-working DVD player) on its own might fetch a reasonable price on an auction site - anyone who has a stolen DVD unit will probably be desparate for the speakers as Sony don't sell them separately!
Top Jamo Audio Players & Recorders Experts
 Grubhead
Grubhead
ADMIN Andrew
ADMIN Andrew
Are you a Jamo Audio Player and Recorder Expert? Answer questions, earn points and help others
