If you set the play mode to shuffle. It should shuffle whatever you are playing, be it All Music, An album or a playlist.
you can set the player to shuffle by pressing the "M" button. from the menu choose "Repeat" mode press "Previous/Next" to scroll through the options until you get to "shuffle". [Press "Play/Pause" to confirm and press M to return to sub menu.
SOURCE: living solution mp3 player
i have a living solution mp3 and i don't know how to put songs on it
SOURCE: How do I reset an mp3 player?
Each Mp3 player has a different reset method - go to manufacturer's website and look at the manual for that method if you have no manual.
For the RCA TH1100 series, the reset method is to remove and reinsert the battery, or change battery.
Reformat your player to clear up the no available space issue.
SOURCE: GPX ML638B won't play random
When a song is playing, press the Menu button - select Play Mode - and take it off of Repeat
SOURCE: Every time I turn on my Sony Walkman MP3 player,
Try Resetting it and if that does not work you may need to format it and reload all your music on.
SOURCE: cant get my sony walkman mp3 player to shuffle the music
Please reclassify question, you are asking about a sony walkman and this is classified under iPod Shuffle. Thank you.
i need the driver for my bush mpk8099buk mp3 player. my pc says it cant recognise the device and so wont load the driver
