Have the engine codes pulled to see what is at fault . This will guide you to the root cause. A local Checker or Auto zone can help with code retrieval .
If the car died while you where driving it, it sounds like it is the alternator. Did it start right up or did you have to boost it? If you had to boost it to start it again,I would say it is the alt., but if it started right away w/o a boost, it is something else.
Battery light on ! alternator isn't charging . Test the alternator electrical circuits .Main cable on the back of the alt. should have B+ voltage .Pin # 3 at the connector on the alt. should have B + voltage - fuse F10 10amp under hood fuse box supply's B+ to pin #3 . Pin's 1 & 2 at the connector go to the PCM - engine computer . This is a computer controlled charging system . Ford PCM controlled alternator testing
fuel pump or fuel filter. have someone kneel near fuel tank and listen for buzzing noise when ignition is turn on if you hear the sound i would change filter
either your alternator has gone or your fan belt is not there which helps the alternator to charge the battery get a volt meter on your alternator to see if it is kicking out what it should be
