SOURCE: grease /oil spots on clothes coming from washer
This sounds like the drum bearings are starting to wear and allowing grease to infiltrate through the inner seal.Does it sound noisy on the spin cycle.
SOURCE: Oil/grease leaking into tub. Speed Queen
Check to see if the oil is coming from under the agitator. If it is replace the transmission. If it is not check to see if there is a grease spot inside the was tub.
