Question about LeapFrog Leapster 2 Learning System
I can't calibrate the leapster.I can't get pass enter a name
  • 2,632 Answers
Welcome to Fixya. If you need to sync the device to the stylus just follow the steps below.
1. Turn your Leapster 2 off, and remove the game cartridge
2. Hold down the 'hint' button while the game is off. The 'hint' button is the middle small button in the row of three above the directional pad on the left, with a '?' on it.
3. With your finger still firmly on the 'hint' button, turn the Leapster 2 back on. Keep your finger on the 'hint' button.
4. The screen should be displaying the calibration screen. You can release the 'hint' button now.
5. Press the 'A' button on the right to enter the calibration screen.
6. A small '+' sign will appear on the screen. Touch it with the stylus. A new '+' sign will appear. Touch this with the stylus too, and repeat for as many '+' signs as your Leapster 2 throws at you.
7. The screen will return to the calibration screen. You can now turn the machine off. Leave the cartridge out of the console, and turn it back on.
8. Your stylus and touch screen should now be working, enabling you to sign in as usual.
9. If it is working correctly then you can turn it off, add a game cartridge and turn it back on.
If you have questions please let me know.Thanks for using Fixya
Posted on Aug 03, 2011
6ya staff
SOURCE:
Forget the code for enter parent lock i no remember the code for leap frog
Instructions
    • 1Put the screwdriver into the screw hole in the small panel on the back of the Leapster. Remove the screw, and open the panel.
    • 2 Remove the batteries from the Leapster and discard them. Find the small "reset" button behind the panel cover. The reset button should be black or red
    • 3 Press the reset button with the pointed object. Hold the button down for about three to five seconds.
    • 4 Put fresh batteries into the battery chamber. Make sure the flat side of each battery connects with the springs in each battery channel. Screw the panel cover back into place.
    • 5 Press the Leapster's "on/off" button. When the Leapster comes on, enter the country informationicon1.png and the player's name.
    • 6 Press the "hint" button, which opens a pop-up help menu. Press the "A" button. Use the stylus to touch the center of the small crosshairs on the screen to calibrate the touch screen.
Read more: http://www.ehow.com/how_8430044_reset-leapfrog-leapster.html#ixzz33FgzCf1j
May 31, 2014 | Toys
The pen on my sons leapfrog leapster won't work
Push the "A" button to enter the calibration.
There will be a little plus sign. Touch it with the stylus and continue to touch the plus signs with the stylus until you return to the calibration screen.
Turn the Leapster off and then back on again without a cartridge.
Sep 05, 2012 | LeapFrog Leapster 2 Learning System
When the main screen comes on and says touch your name with the pen it does not resond what do i do?
It sounds like the TouchScreen needs to be calibrated.
1. Hold down the Hint button while turning the Leapster on.
2. When the Leapster menu screen appears, press the A button.
3. Touch each of the crosshairs that appear with the stylus.
4. Restart the Leapster.
Hope this helps!
Feb 27, 2011 | Leapster 2
Its going on but when it gets to where you touch the screen to which is your name to go into the game and play its not responding....it keeps telling you that if you see your name touch it or play as a...
I had the same problem and here is the answer I found at leapfrog.com.
If your Leapster2 has this kind of problem, it needs to be calibrated.
Calibrating the Leapster2 is easy:
1) Ensure that a cartridge is not inserted
2) Hold down the Hint (?) button while turning the unit on. Continue to hold the Hint button down until the LEAPSTER menu appears.
3) When the LEAPSTER menu screen appears, press the A button
4) Touch each of the crosshairs that appear with the stylus
5) Restart unit
You can also visit the website for more information.
Jul 16, 2010 | LeapFrog Video Game Consoles & Games
We have a Leapster 2 less than 1 year old. It
We have the same problem and our leapster is only 2 days old.Do Touch Screen Calibration,it should help.I do it everytime for my son when he wants to play and it does help...But once u turn leapster off,u'll have to calibrate it again next time...
Just hold down hint button while turning on.When the Leapster menu screen appears,press the A button.Touch each of the crosshairs that appear with the stylus.restart unit. ..That what we do everytime.
Dec 03, 2009 | LeapFrog Leapster 2 Learning System
My Leapster 2 comes on, shows the name on screen & ask to touch my name w/ the pen; however when I touch the name, nothing happens. It keeps asking to touch a name or "guest".
Answer
I had the same problem and here is the answer I found at leapfrog.com which fixed my daughter’s disney princess leapster 2’s problem. Good luck!
If your Leapster2 does not respond to the stylus pen, it needs to be calibrated. Calibrating the Leapster2 is easy:
5) Restart unit
Jul 28, 2009 | LeapFrog Leapster 2 Learning System
Problems entering name/signing in
1) Ensure that a cartridge is not inserted 2) Hold down the Hint button while turning the unit on 3) When the LEAPSTER menu screen appears, press the A button 4) Touch each of the crosshairs that appear with the stylus 5) Restart unit
Dec 28, 2008 | Nintendo Game Boy Advance Console
Leapster can't read input
You need calibration
Touch Screen Calibration is as:
1.) Ensure that a cartridge is NOT inserted.
2.) Hold down the Hint (’?') button while turning the unit on.
3.) When the LEAPSTER menu screen appears, press the ‘A’ button.
4.) Touch each of the crosshairs that appear with the stylus.
5.) Restart the unit.
Dec 25, 2008 | LeapFrog Leapster Electronic Book:...
Leapster screen
Sounds like it needs to calibrated - see http://gobaco.wordpress.com/2006/10/31/how-to-calibrate-the-leapster-handheld/
for info,
Feb 19, 2008 | Video Game Consoles & Games
LeapFrog Leapster 2 Learning System Logo
876 people viewed this question
Top LeapFrog Toys Experts
Nikki  Mclean
Nikki Mclean
pramey3
Level 1 Expert
Keith Koene
Are you a LeapFrog Toy Expert? Answer questions, earn points and help others
