Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Do you see frost built up on back wall of freezer if so it is not defrosting and this is what needs to be checked, remove back wall of freezer and check these;
Defrost heater-- it usually is at bottom of the evap. coil, to check it remove wires to it ,use a meter set to the lowest ohms setting and check for somewhere between 10-50 ohms if that is what yours is its good if meter reads OL replace defrost heater
Defrost thermostat-- if clips to the top of the evap. coil and is metallic,round , about the diameter of a quarter with a plastic side with 2 wires coming from it(do not confuse it w.thermister),remove wires and check for ZERO ohms WHEN TESTING IT MUST BE COLD so check it when frost is built up,IF meter reading is OL (WHEN COLD) its the problem
Defrost timer or defrost control if has digital display to show tempature
check timer(it could be anywhere except in freezer) by turning till you hear a click,the defrost heater should come on within 5 minutes if the heater does come on the timer is the problem and needs to be replaced,if the heater does not come on the above mentions parts (heater/t-stat) will be the problem.
defrost control is hard for unskilled lay persons to check SO IF heater and defrost t-stat are good replace control
Hope this helps,
Gene
