This is usually caused by either a fuel float that is heavy due to taking on fuel where there is supposed to be an air cavity or.
There is debris in the float needle seat allowing excess fuel to over-fill the float bowl. The float needle has a rubber tip that seats against a tiny fat rubber washer called the seat. If there is debris in between the seat and the needle tip the fuel will NOT shut off causing the symptom you descibed.
If you provide a model number I will look up the inexpensive repair parts that will correct this symptom and provide you with a parts source.
Thanks for choosing FixYa,
Kelly
