Check your heating element..
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
How to Replace the Dishwasher Heating Element
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and seehow simple it was. thanks Ronnie " - ronnieshomes
These two lights indicate a fault in the heating circuit.
You would require to have access to and be able to use a multimeter to test the heater if the machine isn't actually heating the water.
If it is heating the water then obviously we know the fault isn't with the heater.
Check the heater first.
Take the door apart and check the wiring in the door isn't broken.
If everything checks ok, take the pcb out, look for burned or dry joints around the relays.
