Panasonic KX-T7633 Corded Phone Logo
Posted on Aug 03, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I can not set up my voice mail The person before me changed the password and it is locked please help
Carl Navarro
Level 3:
  • Panasonic Master 2,460 Answers
  • Posted on Aug 03, 2011
Carl Navarro
Panasonic Master
Level 3:
Answers
2460
Questions
Helped
1154960
Points
7314
If it's a Panasonic TVx voice mail system, your system owner can change the password from Mailbox 999. It's something like option 4 then 3 which resets password in mailbox ***.
Carl
I need to set up my voice mail for conssumer cellular on my Iphone 4
Good Morning, Here are Step by Step Instructions on Setting Up Your Voicemail. Hope This Helps..
You must set up your mailbox the first time you use your U.S. Cellular Voice Mail. Please ensure you are using your wireless device for the initial set up.
  1. Access your mailbox by dialing *86 or your 10-digit wireless phone number + SEND
  2. Follow these prompts to set up your mailbox:
    1. Choose English or Spanish as your language preference
    2. Set up your 4-10 digit password
    3. Record your voice signature
    4. Record or select your greeting
  3. Start using your Mailbox Password
To protect your privacy, the new Voice Mail system doesn't allow "easy-to-guess" passwords, including repeating digits (3333), consecutive digits (1234 or 4321) or ascending or descending even/odd numbers (2468 or 7531). Your choice of a unique password will be an important step in protecting your Voice Mail service.
I need to change my voice message
1 Call your Motorola voice mail service. Press the "Contacts" or "Address Book" button and select the "Voice Mail" entry. Press the "Call" button.
2 Enter your password. Call the service provider for your Motorola phone if you cannot recall it.
3 Delete all voice mail messages. In order to access the main menu you'll be required to empty your inbox.
4 Select "Change Personal Options," then choose the "Change Voice Message" menu. Disconnect the phone call to save your settings.
1helpful
Changing user on voicemail
ill need to log into Manager and under that users tab, you can reset the password or delete the mailbox.
GOOD DAY HOW CAN I CHANGE THE PASSWORD TO A MAILBOX ON A SAMSUNG DCS (SVMI)
to change your password for your mailbox on your Voice Mail, dial into your Voice Mail, enter your password then press # , this takes you into personal services, the prompts will talk you through changing passwords etc for Voice Mail. I have posted a Video with Voice Mail hints and Tips , there are more like this on Youtube search 'abbeytel' or go to www.abbeytelecom.com. I hope that this helps you.
2answers
Want to turn off voicemail Don't know codes
To turn off voice mail please dial ##002#, this would do the trick.
Regards
1helpful
Verizon voice mail access
Yes go into the settings of your voicemail for verizon.. Listen to the prompts and go into setting change your administration settings to turn off password
If you found this helpful Please rate Me Thank you
How do i set up voice message on tracphone V 170?
call voice mail and lisen to the instructions. listen all the way through and the voice mail lady will tall you.
1helpful
2answers
Change night message
the night mode message that is being used is the main phone's (phone with lowest Ext. number) night mode message that was customized through it's voice mail.go on the main phone and listen to its voice mail. (voice mail ext. usually 165)continue listening until you hear some options.select the voicemail management optionthen select the change personal greeting optionthen select the after hours greeting optionhope this helps!
REPROGRAM USER NAMES PASSWORDS
This will be an incomplete answer because you asked an incomplete question.
The first pat of your question involves access to the voice mail system. You can change it from a PC with software to access the system, or from the system manager's mailsbox (999). WHen the system was installed, you should have been given instructions and a password to that mailbox. You log into the manager's mailbox and select options 6 then 1 then 1 to edit or 3 to reset the password.
Easiest for you is to reset the password and make each mailbox owner do his own name, password, directory characters, and greetings.
There are at least 2 ways to get someone's call to voice mail. The first is by setting call forward at the phone. That's the *710x (VM) # that you dial from the intercom. My voice mail system is at ext 165, so I use *7104165# to send it to VM only when I don't answer. The 4th digit options are 2 for all calls, 3 for busy 4 for no answer, and 5 for busy/no answer. Once you set it, the FWD/DND button functions as a selector.
The second way is, if you know the person is not going to answer, you set up a VM Transfer button.
That's where you take a spare button of the 24, label it, and dial the following. PROG press the button 94 (VM) ENTER. Again, mine is 94165.
The 3rd way involves system programming and has to be set up by the system installer. It involves extension intercept and has timing parameters and destinations that need to be programmed.
I think I got most of your question answered. Post again if you have any questions.
Carl
80helpful
6answers
Nortel T7316E
To reset passwords for Feature 983 do the following
Press Feature 985
Press 9
Enter 73738767793
Press OK
Now go back to Feature 983
Enter 120000 for 2-digit extensions, 1020000 for 3-digit or 10020000 for 4-digit
Top Panasonic Lands Phones Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
