my arc s had the same problem when using the internet for long periods. its never caused any problems but if its running really slowcheck which apps you have running and shut down the ones which arent important, and update your operating system to the patest version. my battery used to last round 8 hrs now well over a day. i make sure i only run the apps im using, keep my display brifhtness low and only connect to the internet when using it, this should improve your battery life no end. it will still get hot if your using it for long periods, its no danger but you can place a playing card inside against the battery which will help reduce the heat you actually feel. hope this helps much love CHRISPY
Sounds like you can't add applications not update. Generally in Google Play there are some apps that do not work with some phones. It depends on the developer. If you previously had an application that no longer updates then I would suggest asking the developer if it is compatible with your phone. Another solution is going into your app and clearing your data.Your Android questions answered. With links to articles.
Looks like your bluetooth apps might be causing the issue. Try to reset to factory settings. You will loose everything but it "might " solve the problem. If not, then it's the bluetooth module who's dead.
