go to PGM 3 then go to 1- Machine Feature go to 9-Tax Table go to 1- tax table 1 set tax rate to 5.0000 set Rounding to Round up set singapore Rounding to Round up if you are not using the 1 cent anymore set calculation Type to Table and Add on
Press ESC to go back to Tax Table window and choose 2- Tax Table 2 repeat the same steps as for Tax Table 1 but set the tax rate to 9.98
SETTING YOUR TAX RATE you hold your set % button down for three seconds until set shows again, then hit tax rate button it shows your tax rate, change your tax rate then hit set your tax rate should be set.
cliff notes: hold set% button hit tax+ button change the desired % hit set done Do rate the solution.
I found it by myself, I can help you.
1. Press (AC)
2. Hold (Rate) for about 2-3 second
3. Press (Set / TAX+)
4. Input the tax rate
5. Press (Set / TAX+)
6. Hold (Rate) for about 2-3 second again
7. Press (Set / TAX+) again
And Then you can test the rate .
Found this on the casio site worked fine on my ms-120TE 1. Press [AC] 2. Hold [SET/%] key for about 2 seconds until set and a 0 is displayed 3. Press [TAX+] 4. Input the tax rate 5. Press [SET/%]
this is the link:- http://www.casio.com/support/content/AF64A1AC-193D-4650-A9A9-98BB6FE26CFE
1. Switch off the calculator
2. Switch it on again
3. Press and hold the tax button (set %) until the display changes
4. Enter the new tax rate
5. Press the tax button (tax +)
Any problems contact [email protected] - he emailed the solution to me and it has worked.
