010-327 Fuser On Time Failure RAP
• After the Main Lamp turned On during warm up, the Control Thermistor did not detect
READY temperature within the specified time.
• After the Main Lamp turned On during standby, the Control Thermistor did not detect a
specific temperature within the specified time.
• After the Sub Lamp turned On during standby, the Control Thermistor did not detect a
• After the empty rotation started, the Control Thermistor did not detect the empty rotation
finishing temperature within the specified time.
• After the Main Lamp turned On during printing, the Control Thermistor did not detect a
• After the Sub Lamp turned On during printing, the Control Thermistor did not detect a specific
Initial Actions
Check for paper on the Fuser. The Fuser has no paper wrapped round it.
No)Remove the paper.
Yes)Check the installation of the Fuser Unit. The Fuser Unit is securely installed.
No)Install the Fuser Unit securely.
Yes)Remove the Fuser Unit. Check the conductivity of the contact points of the Thermostat. The
contact points are connected.
No)Replace the Fuser Unit
Yes)Check the resistance of the Main Lamp between P600-3 and P600-7 for an open circuit or a
short circuit . The resistance of the Main Lamp is 100 ohms or lower.
Yes)Check the resistance of the Sub Lamp between P600-1 and P600-7 for an open circuit or a
short circuit . The resistance of the Sub Lamp is 100 ohms or lower.
Yes)Check the resistance of the Control (Center) Thermistor between P600-5 and P600-6 . The resistance is 3k ohms or higher.
Yes)Check the resistance of the Rear Thermistor between P600-2 and P600-4 . The resistance is 3k ohms or higher.
Yes)Check the wire between J410 and J600 for an open circuit or a short circuit . The wire between J410 and J600 conducts with less than a few ohms.
No)Repair the open circuit or short circuit.
Yes)Check the wire between J6 and J600 for an open circuit or a short circuit . The wire between J6 and J600 conducts with less than a few ohms.
Yes)Check the wire between J401 and J523 for an open circuit or a short circuit .The wire between J401 and J523 conducts with less than a few ohms.
Yes)Replace the Fuser Unit . If the problem persists, replace the Power Unit . If the problem persists, replace the MCU PWB .
END
