Nokia N8 Cell Phone Logo
A
Anonymous Posted on Aug 03, 2011
Nowdays i am using N8 mobile set. But Today while i was Saving the confugration for net connection. It was hang still . What is the problem ? and what can i do to fix this problem ?
Abhishek Gautam
Level 3:
President:
  • Master 225 Answers
  • Posted on Aug 03, 2011
Abhishek Gautam
Master
Level 3:
President:
Answers
225
Questions
Helped
51758
Points
1075
Reset your phone by using secret code you can find the secret code in twilightwap.com>phone arena>mobile zone
>secret codes>nokia
Whatsapp has stopped working on my nokia c300,it says server not connected
it needs net connection, if u alredy have net connected, save your settings, go 2 internet options save your using sevice eg: Aircel pocket internet, vodafone mobile connect, airtel GPRS search your available server and save the settings, or call your customer care and tell them 2 send the gprs settings, after saving the settings, switch off your mobile and after a minute, then use it. after this if it is not solved there will be a problem in your software, re-install and use.
Can we connect n8 to any wireless router
if n8 can connect internet without wireless router than you can connect it if not dont buy
4helpful
When im open nimbuzz in my nokia n8 then hang
Hi.Un-install and reinstall it.I also use Nimbuzz but I did not face this kind of problem.Good luck
My N8 is recently not connecting to the internet. It shows the following messages when I try to connect it through my AIRTEL connection : Connection failed Connection Unavailable and Network Error -...
Bro first delete all the setting from ur cell phone ask for new setting 4m ur operator.after saving settings pls switch off d phone & start it after few seconds and now try connecting to net
Hello,can you pleace hel me unloced my nokia N8 IMEI number:3569988042636098
Using codes you can unlock your nokia mobile because its safe for your mobile...........Get the unlock code for your nokia n8 model mobile here Superunlockcodes.com , it gives the easy instructions for getting the unlock code for your mobile .........
2helpful
How to activate web on N8 china mobile
Normally network operators do not support automatic setting for Chinese clone mobiles.
Although you can manually set GPRS and MMS setting.
Here is list of Internet GPRS& MMS settings from operator all over the world,
Click here to see the list
4helpful
4answers
I forgot my nokia n8 security code and want to hard reset it but asks security code
Hello
You can generate the code by using this tiny software.Just follow the procedure.
1. Downoad [ANT] Simple Ant Simple.zip
2. If you have Nokia PC Suite running, be sure to close it by exiting from the taskbar icon.
3. Extract [ANT] Simple ] and run Simple.exe located in the folder
4. Connect the phone via USB to the computer by selecting Pc suit/Ovi suit when prompt a message in your pone.
5.After you've connected your phone, Click "Read Info"
6. On the MAIN tab, click on GET. Your phone IMEI number and model should be displayed on the bottom panel
7. Now click on the SERVICE tab and click on GET button under USER CODE
8. Your security code should now be displayed on the right side of the application window.
If you could not understand follow this How to Generate Your Phone Security code..Only for Nokia bb5 after this format the phone by using the code.Good luck
Thanks For visiting Fixya
3helpful
I have nokia n8 china make...m not able to open gprs..pls send me settings for airtel gprs setting for china make n8....n m also want to opreate my facebook n orkut account frome my same mobile thanks...
i have nokia n8 china make...m not able to open gprs..pls send me settings for airtel gprs setting for china make n8....n m also want to opreate my facebook n orkut account frome my same mobile
7helpful
NOKIA N8 MOBILE SECURITY CODE
FROM MENU-SETTINGS-PHONE-PHONE MANAGEMENT-SECURITY SETTINGS-PHONE AND SIM-LOCK CODE(usually 12345 for N8)
86helpful
45answers
Free unlock code for nokia n8 locked to 3
how to unlock security code of nokia n8?
Top Nokia Cell Phones Experts
Kolbrun...
Muhammad Irshad...
Muhammad Irshad...
