SOURCE: Won't turn off and cylces through colors
Hi. This evening, I had the exactly the same symptom. I found a way to fix it.
When you power up the screen, keep the power and auto buttons both pressed. That seems to reset the screen. After that when you open the menu, a small F appears on the left side of the contrast icon. Go to that red F with the arrows and press menu. Another menu will popup. Choose 'Burnin' and set it to off. That's all !
Note: do not try to change other settings, they depends of the harware...
SOURCE: monitor has shadows from left to right
I actually just got a monitor from one of my friends and on startup it works fine but when I log in it gets the dark shadow from left to right. I belive that all I need is a blaack ight fix so it may be the same thing on yours.
SOURCE: Monitor Flashes Colors when system powered down
Reset factory settings. Push the selection button (second button from the left at the bottom of the monitor, next to the AUTO button), then go the the Factory Reset by pressing the minus button. Press the selection button again, and when it asks if you want to reset say YES by using the minus button. It's a quick fix!
SOURCE: samsung Syncmaster 205 BW,screen went black,power
Please look for bad caps as shown in my pictures, http://s807.photobucket.com/albums/yy352/budm/Samsung%20205BW/
Common problem on all LCD monitors.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
