SOURCE: Wont turn on
your all in trouble.. im on my third one..a pro surfer/shaper... you must wast it completly with fresh water immediatly after leaving the sea.. the chrome corrodes within hourd and allows the seals to leak. also sand etc gets stuck in the lense door...
SOURCE: My Casio Exilim S770 won't turn on or charge
Wow I can't believe how many people this happened to. I have the same camera and is under warranty but they said would not cover the battery. I got on Ebay and purchased another battery that came with a charger and was only 12.99 for the pair. The battery is an NP20. It is not the camera or the battery it is the charger. Apparently there is a problem with the charger on this. Trust me get a new charger and the battery will charge and work. Thanks
SOURCE: My battery wont charge.
Hi I am Vortah The red light is usually an indicator that the battery is charged however in this instance as you are saying it isn't the battery has possibly gone short and you will need to replace the batteries . They have a type of internal memory and only charge a certain amount of times before they no longer accept charge and merely overheat during charging .. But I have to say it may be possible the charger is faulty as if the internal rectifier that charges the battery has gone short that may also bring the red light on in some chargers .. so try the battery or as I would do take it along to your nearest dealers and get them to check it . it may save you money in the long run you could be buying a battery you still cant use when you actually need a charger .. Hope this helps regards Vortash
SOURCE: my casio gz boulder phone
Hi, it's a common known problem that this phone's internal charging system FAILS after about 4-12 months...I have to literally tie a rubber band to the charger's "line" while the phone is being charged to get it to work. (You know--when the red light comes on it's charging--so you have to get the charger line in a certain place & keep it there so it will work.) A real pain in the ***--I'm 17 days from an upgrade--which sux, because I like this phone other than this. Of course, verizon no longer sells it--probably for this very reason. Good luck & just keep the phone as "still" as you can when it's charging. Oh, and I have the charger cradle--that was the first thing to GO as far as charging. I WON'T WORK AT ALL....
