Ariens Zoom 42 In 165 HP Briggs  Stratton Zero Turn Riding Mower () Logo
Posted on Aug 03, 2011
When turning on pto blows the fuse - Ariens Zoom 42 In 165 HP Briggs Stratton Zero Turn Riding Mower ()
Anonymous
Level 1:
New Friend:
  • Contributor 14 Answers
  • Posted on Aug 03, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
14
Questions
Helped
4564
Points
27
Look over the entire wiring harness wherever it may be touching metal as it probably is chaffed, simply tape and zip tie it away from the ground source.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jul 04, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
857
Points
Ariens ezr 1742 engage blades and starts turning not at full blast then shuts down do it again turns little and then stops again
2answers
Engine dies when u turn on th pto
Likely there's an electrical short to chassis frame. You'll need to isolate the multiple circuits that pass through the PTO switch to identify the offending circuit and test for continuity to battery negative.
Wiring diagrams are included in the parts lists from the Bobcat website https://www.bobcatpartsonline.com
Apr 11, 2023 • Garden
Cub Cadet Series 3000 will not turn over.
Pull the connector from the back of the PTO switch and the 4 wire connector at engine. Replace fuse. Turn key to run.
Did fuse blow? No, turn key to start and back to run.
Did fuse blow? No, plug in engine connector.
Did fuse blow? Yes, likely shorted regulator or safety miswired.
Plug in PTO switch.
Did fuse blow? Yes, likely safety miswired.
On 16.5 Yard Man when blades engage the fuse blows
do you have an electric PTO if you do ,it sounds like it's shorted out causing the fuse to blow. disconnect the plug in at the pto try engaging pto switch .Does fuse still blow? if not Its the PTO unit mounted on the crank shaft . replace.
When i turn on the pto it blows the 7.5 pto fuse
Sounds like you have either a dead short causing the fuse to blow, or something is binding and causing the fuse to blow. Check the mechanical end first, does everything move freely? Then check for exposed wires or sparks when engaging the PTO.
Keeps blowing fuse
There are several things that can cause the fuse to blow. PTO stands for Power Take Off and most likely this will not be the problem unless it blows the fuse when it is turned on. What you are saying is the fuse is blowing by just turning on the switch will be a short which can be anything from a pinched wire, shorted diode, short in the stator. bad voltage regulator.etc
Why does my mower keep blowing the 20 amp fuse
could be the safety switch for the pedal
Turned pto off when finished mowing then turned it back on and it does not come on
check the wiring to the PTO first. if it is good either the PTO or its inline fuse has failed. try the fuse first as it is much cheaper. if it just blows again you are back to replacing the PTO.
1helpful
Blows fuse for blade clutch after 20 to 30 secounds ...
Most likely there is an internal short in the PTO clutch, but it could also be in the wiring, which is way cheaper to fix! So, with the engine off, get down on the ground, find the PTO clutch (it's between the two pulleys under the motor) and trace the wires that go to it. Look for a worn spot in the insulation anywhere, especially likely where the wires pass through the chassis or if they've touched a belt or other moving part. If you find a wiring problem, just splice in a new wire.
Ok, if you found nothing, then unplug the connector that connects the wires from the PTO. Start the engine, drive around, engage the PTO switch (of course, the blades won't spin). If the PTO fuse does not blow, you've proven the problem is in the PTO clutch and you must replace it ($150 or so, sorry!). If the fuse does blow, that's good news, you just have a short in the wiring or in the PTO switch itself. Disconnect the wires from the switch to differentiate those two possibilities. The PTO switch isn't too expensive either. Good luck! Please rate my solution if helpful.
2helpful
Cub Cadet 1861 amp light comes on when the PTO is engaged and after mowing for a short time the PTO disengages and now the 30 amp fuse blows and stops the engine
Sounds like you have a short circuit, either in the PTO clutch, or in the wiring that goes to it. Inspect the wiring for any obvious spots where insulation has rubbed off or burned. Also look at the wiring at the back of the PTO engagement switch for these signs. Before buying an expensive PTO clutch, unplug its connector. Drive around with the PTO switch on (even though the PTO won't activate and the blades won't be engaged). If the fuse doesn't blow, the problem must be within the PTO clutch. If the fuse still blows, it must be in the PTO switch or the wiring from there to the clutch. Use an ohmmeter to trace and find the short. Good luck!
Top Ariens Garden Experts
john h
Mike Cairns
Mike Cairns
Kardoc
Are you an Ariens Garden Expert? Answer questions, earn points and help others
