Garden Logo
Posted on Aug 02, 2011
I have a scotts ridding lawn mower that is made by john deere. it is 16 hp and a 42 in. cut. i bought it used and it dont have any manuels. the deck belt broke and i have no idea how to put the new one on. how do i obtain a routing guide for it.
Anonymous
Level 1:
New Friend:
  • Contributor 14 Answers
  • Posted on Aug 03, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
14
Questions
Helped
4564
Points
27
Get your model number from the mower and go on partstree.com and pull up the mower belt schematics.
2answers
Diagram for the deck belt for a Scott's John Deere 17 horsepower 42 in cut mower
http://www.deere.com/common/docs/stellar/answer-center/Scotts-S1642-S1742-S2046.pdf
I need to know what belts will interchange with a Scotts s1642 deck belt the replacement belt they give me was a KBRV01-DB
Just order it for the model number
265-529 Replacement Belt Scotts S1742 S1642 Sabre ...
https://www.amazon.ca > 265-529-Replacement-Scotts-...
265-529 Replacement Belt Scotts S1742 S1642 Sabre 1542hs 42" Cut Lawn Mower Deck: Amazon.ca: Home & Kitchen.
TadaMark Replancement Lawn Mower 42" Deck Belt for John ...
https://www.amazon.ca > TadaMark-Replancement-Scot...
Replaces OEM: John Deere: M124895; Fits Models: John Deere: Scotts S1742 and S1642; Sabre 1542HS, 1542GS, 1642HS, 1742HS and 1742GS with 42" ...
Scotts S1642 (Deck 42") Riding Lawn Mower ... - V-Belt Guys
https://www.vbeltguys.com > products > scotts-s1642-d...
Scotts S1642 (Deck 42") Riding Lawn Mower Replacement Belt ... My belts arrived when you said they would and fit perfectly. I would order again. ... This was our ... Rating: 5 · ‎6 reviews · ‎US$13.84 · ‎In stock
and more https://www.google.com/search?q=Scotts+s1642+deck+belt
1helpful
John deere d110 not cutting grass
check belt and pulleys --if belt to loose wont turn blades to cut the grass
How do you change the drive belt on a john deere d110 riding lawn mower?
You can look at the manuel that came with the mower or if you did not get one, go to the JD mower web site and look up you model and download the needed documentation. If that is not possible contact the local JD mower dealer and get a copy of the mower deck docs and look at the instructions for belt replacement.
John deere x475 mower will not engage after cutting heavy grass
It is probably full of grass in the mower deck. Clean it out and try again.
I have a Scotts by JD with a 48" mower deck. The spring on the deck has broken. How do I replace the spring? Thanks Rita
The lawn mower you have is manufactured by the John Deere Company. They handle all inquiries and complaints on these lawn mowers. You can contact them at 800-537-8233
Hilary @ Scotts
Jun 23, 2011 • Garden
I have a scotts turfmaster 12.5 hp riding tractor model #C4013050. I cannot keep the belt on the pully for more than 100 ft. I dont have a manuel to see if I ran the belt in the right cofiguration. There...
The belt travels from eng. pulley directly to the transaxel pulley riding on the inside/center of the tractor side of the idler pulley. make sure the belt retainer is on the idler pulley.
Top John Deere Garden Experts
john h
Sean Wright
Sean Wright
Jay Finke
Jay Finke
Are you a John Deere Garden Expert? Answer questions, earn points and help others
