My computer do go off after some few minutes - Computers & Internet
  • bo manning Aug 02, 2011
    what kind of computer is it. I will need the specs, O/S,ram, Hd,etc.
    I will need the exact model number also...
  • 639 Answers
Switch ON the PC, boot the PC in 'Safe Mode' by continuously tapping F8 button after you switch On until you get the Safe Mode Option.
Let windows boot in Safe Mode and log in to windows.
Go to 'Start'--->Programs--->Accessories--->System Tools--->Click 'System Restore'
A 'System Restore' window will appear.
Here you will have to check "Restore computer to an earlier time' and click Next
Now you will find one Month Calendar window with Dates below, go to the previous month by clicking the '<' sign in the upper left hand corner of the Month Calendar and select any date that you see in Bold.
Note: It is better if you could remember from which date you are facing the issue, try to select a date prior to that date.
The detail of that particular date should show "System Checkpoint" and time on the right hand side box. Select that date.
Now, Click on Next and System Restore will start and windows will take a reboot.
After reboot
Go to 'Start' and then Run
write "msconfig" inside Run tab and press 'enter'
inside the 'System configuration utility' window click on 'startup' tab then uncheck all the applications except your current antivirus and press apply then 'ok' and then 'exit without restart' option.
Now right click My Computer and go to properties tab.
click 'Advanced' tab then under performance menu click on 'settings'
go to 'Advanced' click on 'change' and increase your virtual memory to 2048 in both spaces.
1) Delete all unwanted data from Drive C.
2) Delete all data that you have copied from Drive C to External HDD
3) Open My computer and go to Tools---> Folder Options---->Click on View Tab----> Check 'Show hidden files and folders' and select OK.
4) Go to C:\Documents and Settings\Administrator\Local Settings\Temp and Delete everything that you see inside Temp Folder
5) Go to C:\WINDOWS\ here you will find folders like $hf_mig$, here you will have to Delete all the folders starting and ending with $ sign.
6) Empty Recycle bin and restart the PC
NOTE: To check your CPU and memory utilization, run Task Manager. You can start Task Manager by pressing CTRL+ALT+DEL and then clicking on the Task Manager Button. In Task manager, click on the Performance tab and check CPU Usage and PF Usage. PF Usage is an indicator of memory usage. If one or both of these is high, click on the Processes tab, and sort the columns by CPU or Memory to see what processes are consuming the resource. If you are not sure what the process "Image name" is for, Google the name and you should find what the process is for.
If your CPU and memory usage are reasonable, then you may have a different issue. Even if you running anti-virus software, it may be beneficial to scan your PC with another scanner to check for viruses. No anti-virus software is 100% perfect at catching everything. Here are a few good free online virus scanners that you can run to check your PC:
http://security.symantec.com/sscv6/home.asp?langid=ie&venid=sym&plfid= 23&pkj=RRJEDTKJBTVISBYWWYP
http://onecare.live.com/site/en-us/default.htm
http://www.eset.com/us/online-scanner
http://www.pandasecurity.com/homeusers/solutions/activescan/
You should always run anti-virus software. There are several very good, free, anti-virus products available. One good source to read editor and user reviews, and safely download anti-virus software, is http://download.cnet.com -- search for free antivirus software. In addition to the reviews, you can see how many people are downloading the software, which is another good indicator of how popular it is.
I have used AVG Free ( http://download.cnet.com/avg-anti-virus-free/3000-2239_4-10320142.html ) , and Avast Free ( http://download.cnet.com/avast-free-antivirus/3000-2239_4-10019223.htm l ). Both are very good, and completely free. At present I am using Avast on all of my home computers.
In addition to Avast or one of the other free anti-virus software packages, I also run Ad-Aware ( http://download.cnet.com/ad-aware-free-internet/3000-8022_4-10045910.h tml ). Ad-Aware is a free anti-malware, anti-spyware package.
Posted on Aug 03, 2011
SOURCE:
Factory restore
First try disconnecting both the router and modem from power for a few minutes. Also turn power off to the computer. Restart all of the components. Wait a few minutes and try. It will take a few minutes to restore the connections.
Next from the computer access the router. 192.168.0.1 or 192.168.1.1. Usually the ID is "admin" no quotes no caps.
Querry the router and valadate the settings. If not successfull try resetting the router to factory by depressing the button located on the rear of the unit.
26241694-pbq4lewq4mzzco310yjoakmr-1-2.png Hope this helps?
Jul 20, 2016 | Computers & Internet
Disconnecting in a few minutes
Change your position , that might help the signal to be better, wireless signal gets obstructed
Nov 23, 2013 | D-Link Dap-2310 Wireless Access Point
IT FREEZES
Try pressing Alt,Ctrl and Del at the same time for a few seconds and you will get start window. You shutdown your computer and restart after few minutes. If you don't get the window switch it off and start after few minutes.
Annapoorani
Feb 05, 2011 | Computers & Internet
My monitor hibernates after a few minutes..how do I reset it so it won't do that? How do I set the brightness?
Click Start
Click Control Panel
Click Power Options
Change the setting for the monitor from a "few minutes" to "60 minutes" or to "never".
Sep 20, 2010 | Acer 22" X223w LCD Monitor
How do you reset service light on a 2008 VW jetta 2.5
pull the negative battery cable off for a few minutes, or pull the fuse for the computer for a few minutes, or take it to autozone and have them clear the codes with the computer
May 03, 2010 | 1999 Volkswagen New Jetta
Asus Monitor boes blank and comes back after power recycle
1. You can see images on the screen for a few minutes. That means there is nothing wrong with your computer.
2. When your screen goes blank, if you disconnect and then reconnect the monitor, it shows fine again for a few minutes before going blank (or dim) again. That means the problem is not with you video card.
3. It always shows the image after reconnection for exactly a few minutes before going blank again. yes? this means that there is nothing wrong with your cable.
Conclusion: Sorry, but you do not have many options. I bleieve that the problem is with your monitor that's going bad. Its far cheaper to get it replaced than to repair it.
Oct 04, 2009 | ASUS MW221U LCD Monitor
My monitor is not displaying after few minutes when it starts
Connect the monitor to the VGA-output port of any laptop.
Does it work for a few hours, or just a few minutes?
If it works for hours, then your computer's video-card is the problem.
If it works for just a few minutes, then it's time to replace the monitor (it's too expensive to get a qualified technician to try to repair it).
Jul 16, 2009 | LG Computers & Internet
Picture ok for a few minutes then go blank
It's not the monitor it's your video card replace it
May 20, 2009 | Dell E176FP 17" LCD Monitor
Monitor goes off after a few minutes of use. when pressing the on/off button, sometimes will turn back on. if left alone will turn back on after a few minutes. when computer is off, sometimes will turn on...
1.check power supply section any dry points
2. To replace all electrolatic capacitors in Power supply
3.Check Connectors Properly connected Or Not.
4.Replaced Microswitches in Front pannle.
Oct 06, 2008 | ViewSonic VX910 19" LCD Monitor
Open Questions:
ESET TEcH suPPORt PHone [!!!]..18OO8O3..1O69'''' numBer jkrdds Usa ESET USA phone number is ranked #2 out of 2 because 7,728 ESET USA customers tried our tools and information and gave us feedback after they called. The reason customers call # I:8OO:,:8O31069 is to reach t he ESET USA Tech Support department for problems like Where to buy, Complaint, Tech support, Repairs, Returns. As far as we can tell, ESET USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. ESET USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I8OO8O31O69 and ways to call or contact ESET USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling ESET USA Calling ESET USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from ESET USA Tech Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with ESET USA's Tech Support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare ESET USA's phone numbers against each other. Contacting ESET USA in General While I8OO8O31O69 is ESET USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I8OO8O31O69 is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach ESET USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact ESET USA.
Oct 21, 2019 | ESET Computers & Internet
Computers & Internet Logo
57 people viewed this question
Ekse
Marvin
Marvin
