Question about Epson PhotoPC L410 Digital Camera
Does the L410 do audio recording?
Does the Epson_PhotoPC_L_410 do audio recording?
    Genius:
  • 1,447 Answers
Videos with sound is possible or you can record sound memos as well
Recording and Playing Sound Memos
You can record and play back sound memos for your photos while you view them on the LCD screen.
1. Turn the Mode dial to playback mode.
2. Press the MENU button. Playback Menu 1 is displayed.
3. Select Sound Memo by using the u d buttons, then press the r button.
4. Press the OK button and then start recording.
5. When you are finished recording, press the OK button. You can play or delete the sound memo or record
a new memo.
6. Press the MENU button twice to exit the menu.
When you play back a photo that includes a sound memo, the icon appears on the screen. Press the OK
button to play the sound.
Note:
You must have at least one photo saved to record a sound memo.
Posted on Apr 05, 2008
SOURCE:
Why not to use the QuickShot mode?
-you can't use Quick SHot when battery is low -you can't use Hypict mode with Quickshot -you can't make audio recordings with Quickshot
Sep 13, 2005 | Epson PhotoPC 850Z Digital Camera
Is the camera’s internal memory available when a memory card is installed?
The camera’s internal memory is not used to store pictures when a memory card is installed. The memory card becomes the default location for storing pictures. However, the PIF frames and sound files stored in the camera's internal memory are still available.
Sep 13, 2005 | Epson PhotoPC L410 Digital Camera
Is all of the camera's internal memory available for storing images?
No. Aproximately 9MB of the camera's internal memory is used to store PIF frames and sound files.
Can I delete the PIF frames and sound files stored in the camera's internal memory?
Yes. There are two ways to delete the PIF frames and sound files from the camera: * Connect the camera to a computer and drag the EPUDL folder and EPSOUND folder to the recycle bin or trash can on your computer. * Format the camera’s internal memory. Note: If you plan to restore the sound files to the camera’s internal memory, save a backup copy of the EPSOUND folder before you delete the folder.
The camera does not take a photo when I press the shutter button. What should I do?
Check the following: * Make sure the battery or batteries have power and are correctly installed. You may need to replace the batteries. * Make sure the power is on. The camera may have turned off automatically to save power. Press the POWER button to turn the camera on. * Make sure the Mode dial is set to the correct mode. The shutter button will operate when it is set to Manual mode, Automatic mode, Continous shooting mode and Video mode. * Check the number in the lower left corner of the Camera’s LCD screen. If the number is 0, the memory card (or internal memory) is full. Copy the photos to a computer and delete them from the camera.
Nothing appears on the LCD screen. What should I do?
You can try a new battery for it or reseat the flash card if that doesnt work still try another flash card.
CanI use a non-EPSON AC adapter?
EPSON only guarantees the EPSON AC adapter for the PhotoPC 500. Other non-EPSON AC adapters are not recommended for use because they may damage the camera and possibly void the warranty.
Sep 12, 2005 | Epson PhotoPC 500 Digital Camera
The camera may have shut off automatically to save power. Press the POWER button to turn it back on. Also make sure the mode dial is turned completely to the desired mode. When the camera is connected to a computer, the LCD screen is disabled. When it is connected to a printer, press any button to display the print progress screen. After a moment, it disappears again.
Sep 12, 2005 | Epson PhotoPC L410 Digital Camera
The LCD screen is hard to see. What should I do?
If the LCD screen is too bright or too dark, adjust the LCD Brightness setting in the Setup Menu. If you are shooting photos outdoors in bright light, move the joystick to the icon showing the sun over shaowed area to turn on Outdoor mode and make the LCD screen easier to see in bright light.
Epson PhotoPC L410 Digital Camera Logo
635 people viewed this question
Top Epson Cameras Experts
Steven Wander
Steven Wander
Terry Herrera
Harrie
Are you an Epson Camera Expert? Answer questions, earn points and help others
